Headlight wiring diagram
MILTDART2
  • JEEP CHEROKEE
I have a 1995 jeep cherokee sport w/ 217k miles, automatic. I need to find the wiring diagram for the headlights.
My head light switch is not working and does not turn on the head lights. Also, the highbeam switch won't stay on High beams. The result is I have no head lights.
Is there a wiring diagram I can download or could it maybe be a fuse issue?
Thanks in advance,
Milt
Friday, November 2nd, 2007 AT 7:04 AM
MIKE H R
  • 3,094 POSTS
Here are the headlight wiring diagrams for both DRL and non DRL headlight systems with a guide to show you how to test the wiring.
Friday, November 2nd, 2007 AT 10:46 AM
EMCRETIRED
  • 1994 JEEP CHEROKEE
Electrical problem
1994 Jeep Cherokee Manual
My headlights have recently stopped working, I have all of my marker lights, my turn signals, and my backup lights. I have checked and the fuse is not blown, that I could see. I would deeply appreciate it if you could get back to me as soon as possible.
Wednesday, January 9th, 2019 AT 12:26 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Are both the dim and high beam lights out?
EMCRETIRED
Yes but still have passing lights, was able to verify harness to be ok to lights. Have a manual and it says somthong about a circuit breaker in the system? Unable to locate it.
Wednesday, January 9th, 2019 AT 12:27 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Circuit breakers provide a similar protection to fuses. Unlike fuses most circuit breakers only have to be reset, and not replaced. Circuit breakers are used only in models equipped with power windows, and are located underneath the front seat. Check to see if you have this. If you do, reset it and post your results.
JNOVACK
  • 723 POSTS
Check fuse #15 under dash and fuse #4 in engine compartment there is not any cercuit breakers in you jeep if those fuses are go then you will have to check the grounds and check the wireing from the lights to the fuse box also check to see if you have power to the light socket
EMCRETIRED
Thanks for the help. I found it was a intermittent problem with my headlight switch located on the dash. Replaced it and also checked the plugs for the lamps and the wiring harness, all is working well. Again thanks for your input
NOTSMALL
  • 1996 JEEP CHEROKEE
  • 63,000 MILES
Lights work except high beam on passenger. I get no continunity at the high beam harness plug on Passenger side. Low beam works. Where does the harness run from the drivers side to the Passenger side? Are there any plugs to check along the way? Are there any common problems for this particular malfunction?
KHLOW2008
  • 41,814 POSTS
Is your vehicle equipped with Daytime Running Lights?
Have you checked/tested the bulb?
NOTSMALL
No daytime lights and yes, the bulbs work on the drivers side. There are two red wires in the high beam side of the plug on the drivers side. One apparently goes to the Pass. Side which only has one red wire into the highbeam portion of the plug. No power or continuity to the pass. Side red wire. Apparently there is a break between the Driver and passenger side. The wires disappear into a loom and I am wondering if the is a plug to check.
KHLOW2008
  • 41,814 POSTS
Attached are the schematics. Passenger side (right) has the Red/Orange wire running from between the two headlights.
When high beam is turned on and you do not have battery voltage at this wire, it means a break in between.
NOTSMALL
Got it, Thanks. Do you know where the wire runs? I see where it ends up but I don't know where it physically goes. Is there a plug some where that could be compromised?
KHLOW2008
  • 41,814 POSTS
I could not find any information on connectors between the two and wiring between headlights usually come as a single harness which runs across the radiator to the other side. Most wires would break at the ends, meaing the break should be near the plugs for the bulbs. Tug at the wires and note if any parts seems give way/lenghtens and that should indicates a break. Wiggling the wires might help to diagnose which area is faulty.
NOTSMALL
Good ideas. Thank you. When I solve it, I'll report back to you. The harness, BTW, runs back to the firewall and across and up to the battery area (Pass side)
Thanks again
Cordially,
Gary
JOEDIAZ06
  • JEEP CHEROKEE
1990 Jeep Cherokee Laredo 215,000miles.
I have looked and searched everywhere for a headlight switch for my 90 cherokee. It seems that these parts are not being made any more. If anyone knows where to find my jeep headlight switch, besides a junkyard, please share. Thanks
VANDRAGON
  • 298 POSTS
The juckyard isn't so bad, give them a chance, it's worked for me many times.
KHLOW2008
  • 41,814 POSTS
If there are any connections, they should be visible along the harness. Look out for signs of possible damage due to abrasions etc.
Good luck.
95JEEPGC
  • 5 POSTS
I had my lightswitch go on my 95 GC last year. Mine is made in Canada and the lightswitch is in fact wired differently than the American ones. It took a little re wiring, but now I have constant low beams on and no running lights. I got mine from the dealer
