P1698-NO BUS message
JEEP CHEROKEE
GINKOD
  • 6 POSTS
Hi, I have a Jeep Cherokee sport 2001. My idle speed seems very low, I've read in my hand book that it should range between 700-900 and mine is in the low 500. I've replaced the idle air control motor and cleaned the throttle body but the result is still the same. I took the car to a mechanic for a check since my transmission was acting up after scanning the computer he found the following error codes P1698-NO BUS MESSAGE FROM TRANS CONTROL MODULE and P1698-NO BUS MESSAGE FROM TCM (without the check engine light beign on). He tried to clear them but it would not let him, so he advised me to take the car to a car electrician. I recently found out that the car has been in an accident with the prior owner. I guess I would like to know if all these issues are connected somehow and what I should do. Thanks in advance.
Jun 15, 2007 at 9:51 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
It sounds like the connection to the TCM but to but sure lets run the CAN to see what going on this video will help
https://youtu.be/InIlnsjOVFA
Let us know what you find
Jun 18, 2007 at 9:52 AM
GINKOD
  • 6 POSTS
The actual error code is P1694 Fault In Companion Module No CCD Messages Received From ECM". I apologize.
Jun 18, 2007 at 10:33 AM
MERLIN2021
  • 17,250 POSTS
It sounds like the PCM is bad not communicating. I would try a used one to see what happens.
Jun 18, 2007 at 4:59 PM
GINKOD
  • 6 POSTS
how about the idling problem I was referring to in the same question? It idles below 500rpm and I know it should be around 650. I did all the standard stuff. Cleaned the idle air motor removed all carbon from throttle body and put in a new filter and still the same issue. I even replaced the idle air motor at one point but it did nothing. Thanks again.
Jun 22, 2007 at 12:10 PM
RUMSPICE
I had the same error code. I also received the no bus, plus my car would start but then stop. I replaced the crank sensor and it seems to be fixed...
Feb 18, 2010 at 12:31 PM
MERLIN2021
  • 17,250 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Feb 18, 2010 at 2:35 PM
J.STIEG
  • 361 POSTS
Engine had just been exchanged with a 98 4.0l, and installed. Got the engine running after adjusting the distributor. The engine seem to stall suddenly sometimes like there is an ignition failure.
On the dash it says "no bus" and most if not all of the gauges do not work. I can not scan for codes because of linking error.
What would cause a "NO BUS" condition?
Jan 2, 2019 at 6:42 PM (Merged)
Seems to me the cluster has lost its communication with the computer-have the computer checked and tested
J.STIEG
  • 361 POSTS
It was a ground wire not in place on the block.
RIVERMIKERAT
  • 6,110 POSTS
Thank you for letting us know. Closing thread.
WILLYMAC
the gauges don't work and there is a message in the odometer "no bus" and the engine check light is on.
The jeep runs fine in this mode.
The problem is intermittent.
How do I repair?
CJ MEDEVAC
  • 11,004 POSTS
See my profile, imma cj jeep kinda guy, and they are my strongpoint, i answer them.........alot!
I do not know your rig but maybe able to steer you to the right place!.....i am a member like you, they liked my answering (i try to stay within my boundries with my answering), and wah-lah!.....a new title!
I was sorta lost on these computer-rigs too, but i am learning slowly.
1st, check engine light.........you have a code!.....great!........airborne!
Now you need to know what it is and what it means.
Take him to autozone or advance auto.....they can read the code......free!
They see this stuff, all the time!
They can code you, usually, identify the problem, sell you the part, show you where it goes, sometimes--i have seen them install the ez stuff, in the parking lot!
I generally, stay in good repore with them, and if i do not get their help....they steer me to the right place.
The more mature, been there awhile guy, is your target........if its hot out, a cooler with assorted soft drinks, aids in the "good repore, bonding process".....sorta casually grab a soda, a few, "teasing sips".....then force your cooler onto them..........you will be their high-light of the day!!!......you will be remembered the next time!.......i do this at salvage yards, and other places too.........its sorta like a "discount card" also.
Eliminating a shop!
This is not a sure fix
But is a place to start
Return here with some kind of news!
The medic
ORION71
Did you find out whaqt the issue was? My 2000 Jeep is doing the samething.
CJ MEDEVAC
  • 11,004 POSTS
Did you get your rig coded?
What were the results?
Did you discuss this with parts store guys?
The Medic
G&PTWEEDIE
My vehicle runs, but every few days, it runs, the dash mileage meter, and other dash meters stay at zero, at which time. Check engine light comes on, and airbag light comes on. Message reads what looks like "NO BUS 5". Hubby says, car has actually shut off for a time, when these lights and message come on, but it has not when Iha ve been driving. What do I need to repair?
MERLIN2021
  • 17,250 POSTS
This codes and problem happen when one of the computers is going out either the PCM or BCM. I would run the codes to get an idea of which one it is. It will show a code that will give us a clue which one.
Cheers
RADHO1
I had this problem as well the dealer replaced the BCM cost me $430.00 but at least is fixed.
MALIBU66
My jeep is giving the no bus display on my dash. On start up I have no gauges what so ever. The warning lights are engine , airbag, no key. The gauges will come back to life after 5 or 10 minutes driving. If I turn on my rear window defoger switch my gauges come back instantly. When turned off the are all off again. Very strange...
Jan 2, 2019 at 6:43 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Loosing ground from BUS when you turn rear fogger on dash grounds through it. Check connector B on instrument cluster. Terminal B1 white/black wire groune B2 violet/brown voltage. Suspect no ground on B1
ORION71
When driving both the tactometer and speedometer drop to zero, airbag light comes on, check engine light comes on and mileage window displays "no bus" some times it resets itself on its own. Sometimes I can shift to neutral and restart the car to clear the issue. Does not occur every time I drive and sometimes occurs multiple times in one 50 mile trip. Any idea or do I just need to take it in for a diagnostic?
  • 110,190 POSTS
The no bus indicates there is a loss of communication between the computer and its components. Check the wiring harness to it and make sure it is tight and doesn't have any corrosion.
Let me know what you find.
