Engine has sluggish acceleration and low power?
1996 JEEP CHEROKEE
DARKCRISPY
I recently purchased a jeep from a friend. it had transmission problems but I had it replaced. it worked fine for a few days then gradually began to drive more sluggish. i get hardly any acceleration at all and when i do its uneven. the gears seem to switch smoothly.
Also to keep in mind
- it had sat for almost a year
- it has a bad catalytic converter
the engine was rebuilt about a year and a half to two years ago.
I have tried fuel additives and hi octane fuel to try n clean out the fuel injection but no luck on the first try.
suggestions?
Feb 10, 2007 at 11:25 PM
  • CAR REPAIR CONTRIBUTOR
It sounds like you have a map sensor that is not working right or a plugged catalytic converter here are tow guides and diagrams below to help us get the problem fixed.
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Feb 12, 2007 at 5:11 AM
OIDAVEY
  • 0 POST
Thanks for this post I had the same problem and had to get a new MAP sensor cost me $56.00 I love this site.
Jan 18, 2019 at 6:50 PM
JEEPINIT23
  • 5 POSTS
At a point of needed some help. I have a 1993 grand cherokee 4.0 automatic. So it all started driving down and it shut off on me. So I thought it's probably same sensors that always go bad. Replaced TPS, IAC, nothing. Checked fuel pressure, it was a little low changed fuel filter, and fuel pressure regulator. Still nothing. Pulled distributer seen the culprit gears were grinded down completely. Replaced that and finally got it started to get it home off the road. Still had a hard time starting would only start when the engine was cool. So inspected plugs and wires found some wires melted together separated and fixed those. Still had hard time starting. Tested some wires from pcm some were good readings some were bad so replaced that. Now starts up how it's supposed to, but when accelerating from a stop it is very sluggish even with pedal floored. It feels like a timing issue but from what I can find the computer on this model and year fixed the timing with all the sensors. So I don't want to keep replacing every sensor on the jeep. Where should I go from here. It drives and runs just slow acceleration.
Parts replaced already are ;
TPS, IAC, CPS, distributor, spark plugs, fuel filter, fuel pressure regulator, PCM, looked over engine for corroded wires, replaced asd relay, fuel pump relay, changed oil, checked trans fluid.
Jan 28, 2020 at 7:53 PM
  • 54,354 POSTS
It sounds like you could have a clogged catalytic converter. To be sure here is a guide to help test it:
Jan 29, 2020 at 9:18 AM
JEEPINIT23
  • 5 POSTS
An update on the problem. I changed the catalytic converter just because it was original it did not fix the problem. Some other info to help is when in park and I rev it it works fine until 3,000 rpm's then it'll pop or misfire if I slam the pedal. If I slowly rev it at about 3,000 it'll shake a little and not really rev much higher. When driving if i slowly press the gas pedal it'll drive but just takes forever to get to speed. Once up to speed it drives fine unless I slam the pedal then it just revs up and doesn't go any faster. If press it about half way it'll pick up how it's supposed as long as I'm already moving. This leads me to believe it's a timing issue but I followed the directions in the Haynes for setting the distributor. But everything I find on timing is the computer is supposed to set it on its own. Any other thoughts from anyone.
Feb 1, 2020 at 7:17 PM
  • 54,354 POSTS
Yes, the fuel pressure sounds like it is low. you will need a gauge the auto parts store will lend you one. here are two guides to help us:
and
Feb 3, 2020 at 10:30 AM
JEEPINIT23
  • 5 POSTS
That was one of the first things I thought of. I checked fuel pressure and i get the correct readings. I changed the fuel filter and fuel pressure regulator just because they were old. Replaced the MAP sensor still same problem. I put Sea Foam in gas tank to help clean injectors out as well. What is weird it was running perfect before I found the distributor gears were ground down on one side.would the cable to the transmission from the throttle body not working correctly somehow? I can't imagine the timing chain jumped either.
Feb 3, 2020 at 3:39 PM
JEEPINIT23
  • 5 POSTS
Going to try the compression test next.
  • 54,354 POSTS
okay, let me know.
Feb 4, 2020 at 2:14 PM
JEEPINIT23
  • 5 POSTS
Finally got a chance to work on it. After talking with other jeep owners I know and mechanics everything kept coming back to timing. Only problem is, is on the zj toy can't turn the distributor to change the timing. Shop after thinking about it and reading up on things I figured it out. The way to adjust timing on the zj is you have to pull the distributor out and turn the crank pulley and put the distributor back in. Pretty stupid on jeeps part for designing it that way. But jeep is running great after messing with the timing that way. Especially since I replaced about every darn sensor on the engine. I appreciate the help and sticking with me through it. Now it's on to fixing other issues. Jeep-Just Empty Every Pocket.
Feb 6, 2020 at 4:31 PM
  • 54,354 POSTS
LOL. that's a good one. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Feb 9, 2020 at 11:39 AM
MREISHUS
I have an intermittent problem where I will get no power to start the engine. Once started, it stills run great with 170,000 miles. I have tried replacing the battery and battery cables, but still have the problem. In the past I have always been able to get it to start by wiggling and messing with the cable connections at the battery, and I am still able to do this even after replacing the battery cables. But this is annoying to always have to get under the hood to get it started. Happens about every 5th time I start it.
Any other ideas as to what it could be?
Thanks
Jun 18, 2020 at 10:38 AM (Merged)
Check those little wires at the positive battery cable that leads to the power distribution box your problem could be here with a loose wire
https://images.2carpros.com/forum/automotive_pictures/12900_muah1_2.gif
GRICHARDS
  • 57 POSTS
Agree with rasmataz, wiggling wires to re-establish the power connection means loose connection. Track wires from battery to all other terminations, ensure everything is solid. Regarding the wires to the power distribution box, were these replaced, too, or are they original? Wire may have internal break, bad connection at termination to box. Have you put an OHM meter on the cables (power disconnected) to make sure there is Little or virtually no resistance in the wire? Put meter probe on each end, wiggle wire to ensure resistance value does not change - if it does, wire may have internal break....
MREISHUS
The problem is more consistent now. I couldn't get it to start all weekend. I checked again that it's not loose wires. I'm not getting any power to the battery and can't even get it to start with a jump.
Could it be the ignition coil, or something related?
MREISHUS
When I turn the key on, I am sometimes hearing the relays click under the passenger side dash.
SICKLLPUP
Engine Performance problem
1996 Jeep Cherokee 4 cyl Four Wheel Drive Manual 140K miles
my 1996 cherokee 2.5td doesnt keep any power on up hill gradients unless i can get a good run up, it will only rev to 3000 rpm in 1st or 2nd then the power drops off. any suggestions?
[quote:bb419e6dae="mreishus"]When I turn the key on, I am sometimes hearing the relays click under the passenger side dash.[/quote:bb419e6dae]
Inspect and test the ignition switch.
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
MIKEOGILVIE89
mine doing same thing-told positive battery cable sytem(?) part costs $300
TOBYU
  • 89 POSTS
In the fuse relay center next to the battery there is a starter relay....pull it and clean terminals and connectors in relay socket....brake cleaner spray works well.....put some grease or WD-40 on the terminals and try....the loose connection could be at the relay and not the battery cables....
RICHARD RID
Our car keeps randomly shutting off. i very sure it is the ignition switch connector the wires coming out of the connector two of them I burnt up and really corroded. I think it is numbers 7 and 6 I am trying to figure out where the wires go so I can rewire them.
HMAC300
  • 48,601 POSTS
Seven comes from PDC and six goes to junction block also check harness at rear of engine by stud on head it wears through there and causes multiple problems.
GMAN1166
I have a 1996 Jeep Grand Cherokee limited, I am having lost of power, hesitation and cutting in traffic. I have change the distributor cap, rotor, spark plug wires, VVS, spark plugs and clean the troter body. help me out here please!!
Aug 1, 2020 at 12:54 PM (Merged)
PEPPERMRJ
  • 1,158 POSTS
2 more maintenence items to try. Clean the EGR valve and make sure it function properly. Replace the fuel filter and run a tank or two with fuel injector cleaner.
Good luck and let us know. :)
CLEATUS
I read another post about a jeep that described my situation to a T! but i need futher help. The post i am referring to is "recently my 97 jeep cherokee has started sputtering when fuel tank reaches 1/2 tank. loss of power & acceleration as well as bucking. Any suggestions "
there was a reply of "Check the fuel pressure /charcoal canister purge solenoid."
I am a newlywed and dont have any $$$ for a mechanic. any help futher explaining what the purge solenoid is and how to fix it.
Please help.
Start by checking the fuel pressure and comeback with the actual readings that's both vacuum at pressure regulator and w/o it-again I want readings not the thumb or eyeball method
PARKANG5
my jeep grand cherokee loses power and dies at the stop. Then when I put in drive it hesitates with a jerk. The coolent sensor light blinks occasionally. I have been told it is the fuel pump. Any suggestions.
MASTERTECHTIM
  • 4,750 POSTS
you need to check the fuel pressure with a gauge and see if you are actually losing pressure, it could be bad.
SMOKIN27US
1996 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
When I am driving down the road sometimes my Jeep just loses all power and shuts down on me. I have changed the battery and had the alternator tested 3 times and it was good all three times. Do you have any idea what may be causing these problems for me?
CRZYDRVR
  • 432 POSTS
Have the pick up coil and the crankshaft sensor tested. Seems to be a common problem on these Jeeps.
