2CarPros - Car Questions & Answers
2001 Jaguar X-Type Repair Question
Topics covered: Parking brake, Wheel, Lug nut.
Asked on March 10, 2010
2001 Jaguar X-Type HANDBRAKE
Brakes problem
2001 Jaguar X-Type 6 cyl Two Wheel Drive Automatic 80000 miles
HANDBRAKE AJUSTMENT
Avatar Asked by jagman9491
Answer
Replied on March 12, 2010
ADJUSTMENTS
PARKING BRAKE
Parking Brake Cable
CAUTION:Make sure that the rear wheels rotate freely when the parking brake lever is released.
Raise and support vehicle. Make sure gear selector is in NEUTRAL position and parking brake lever is released. Rotate adjusting nut until the parking brake can be applied by raising the parking brake lever 3 to 5 clicks.
Parking Brake Shoes
Make sure gear selector is in NEUTRAL position and parking brake lever is released. Raise and support vehicle. Remove both rear wheels.
Install 3 lug nuts to secure brake disc to hub and tighten to 15 ft lbs. (20 N.m). Remove plug from access hole and rotate brake disc until access hole is aligned with adjuster. See Fig. 3 .
Using a flat-blade screwdriver, rotate the adjuster counterclockwise until the brake disc cannot be rotated.
NOTE:The brake shoe return spring next to the adjuster prevents the adjuster from rotating under normal operating conditions. Make sure that the spring is seated between the adjuster spokes when brake adjustment is complete.
Rotate the adjuster gradually clockwise until the brake disc rotates freely. Install access hole plug.
Repeat parking brake shoe adjustment procedure on opposite-side of vehicle.
After parking brake shoe adjustment is complete, adjust parking brake cable. See PARKING BRAKE CABLE .
Remove lug nuts and install rear wheels. Install lug nuts and tighten to specification. See TORQUE SPECIFICATIONS . Lower vehicle.
Fig. 3: Identifying Parking Brake Adjuster Access Hole
Courtesy of JAGUAR CARS, INC.
http://www.2carpros.com/forum/automotive_pictures/266999_jag_77.jpg
Tiny Answered by Dave H (expert)
13,682 answers provided
