2001 Jaguar S-Type
Engine Mechanical problem
2001 Jaguar S-Type V8 Two Wheel Drive Automatic 104000 miles
If the car is left for more than 10 minutes, it has a tough time starting. Usually it takes 2 cranks to get the car started. I would smell gas or exhaust during the starting period, but then it runs perfect. Note if I turn off the car then trying to start it within the 10 minutes everything starts properly. Also if I disconnect the negative terminal for 20 seconds to reset computer, the starting problems are solved. Then after a couple of days somehow the starting problems comes again. I've already replaced the ECT sensor with no change. Whatever the problem is, it is time sensitive Please advise
May 18, 2010.
Is the vehicle showing a check engine light?. Replace the air filter and clean or replace the MAF (mass airflow) sensor. Also have the fuel pressure checked
Dave H
May 31, 2010.
