2003 Isuzu NPR Repair Question
Topics covered: Transmission, Shifter, Trouble code.
Asked on June 3, 2009
2003 Isuzu NPR check trans light
Transmission problem
2003 Isuzu NPR 4 cyl Two Wheel Drive Automatic 90000 miles
the check trans light keeps flashing on dash , what do you suggest this means
Answer
Replied on December 14, 2010
mine did that and had no symptoms and somehow shifter got misalligned with linkage and was not completely in gear.had to push down harder to get into gear.
Replied on December 16, 2010
An error in the transmission control or sensing system has occurred and the transmission control unit is signalling the problem. You need a scan to retrieve the trouble codes to proceed with troubleshooting.
