AC problems?
2005 ISUZU NPR
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEYSGARAGE
Have a 2005 NPR, The air wasn't working as good as it was a couple of weeks ago and the compressor belt started making noise when the compressor would kick back on after cycling. I hooked up a set of gauges. The high side started rising to 450psi, the low side was at 32 psi. I have never seen high side pressures that high. when the pressure gets this high is when the compressor belt squeaks at start up after cycling. Any help would be greatly appreciated!!! Need asap! THANKS!!!
May 28, 2011 at 5:23 AM
  • CAR REPAIR CONTRIBUTOR
Sounds like its overcharged causing the compressor locking-up I would bleed some refrigerant off so the high side is at 250-260.
This guide can help as well
Cheers
May 28, 2011 at 7:50 AM
MTRDUDE
  • 51 POSTS
VIN #JALC4B14527000163
Having some problems with this customer's A/C and wanted someone's input. I replaced the condenser fan and system dryer using OEM parts in May. A/C was working fine the past two weeks until the outside temps started climbing; I'm in North Charleston, SC and have had temps in the 90's & near 100 the past couple weeks. I have the system charged to good low/high side pressures (no sight glass) and with approximately 44 deg. vent temp at 2000 rpm. Twice in the past two weeks the driver has been on a hour and a half round trip and on the return leg the dryer has blown off pressure from the system and it loses r134a and coolness. I charged it back up the first time and checked and didn't see any problems. The second time I charged it it was showing the high side reading up around 250 psi so I didn't charge it any more. Two days later the driver told me the same thing had happened again, in the same way and on the same route; it never happens on any other route. I checked the system yesterday and recharged with approx. 1/2 lb. of 134a. At idle the compressor engaged readings were 23 psi low/165 psi high & compressor disengaged readings of 40 psi low/165 psi high. At 2000 rpm the comp engaged readings were 20 psi low/210 psi high & comp disengaged readings 40 psi low/165 psi high. The compressor cycle time at idle was approx. 15 seconds engaged/10 sec disengaged; the cycle time at 2000 rpm was 20-25 sec engaged/10-15 sec disengaged. I was thinking earlier that I had a high side restriction somewhere that was causing the HS pressures to spike under certain conditions but the readings I got yesterday don't indicate that. Would like to know the system operating pressures for this vehicle and get any suggestions you may have; dealer hasn't been very helpful with this.
Aug 27, 2020 at 11:43 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Hi
Does condensor fan go into high speed mode? Is there a pressure switch on receiver/drier?
Let me know
Thanks for donate
MTRDUDE
  • 51 POSTS
To my knowledge the cond. fan only has one speed and I think it comes on around 150-170 psi high side; can't remember the pressures for certain. There is a pressure switch on the drier; the original OEM drier also had a sight glass but the replacement OEM drier I installed doesn't. The sister truck to this one has a sight glass in-line just before the high side connector port.
DOCFIXIT
  • 18,828 POSTS
Condensor fan has two speeds check relays one for low speed and another for high. If no high when head pressure goes upit can't cool. Also check pressure switch it is dual for low and high it should cut out long before drier blows.
Refergient full charge is 22.9oz
MTRDUDE
  • 51 POSTS
Thanks, didn't know about the two speeds. Do you have anything that shows what the pressures should be? I won't see the truck till next week but will definitely check this and would like a comparison on the pressures.
DOCFIXIT
  • 18,828 POSTS
Hi
Operating pressure range High side 199-270 Low side 21-43 psi at 77-86 deg. air temp
