1995 Isuzu NPR Repair Question
Topics covered: Engine, Spark, Check engine light.
Asked on June 10, 2009
1995 Isuzu NPR Will not run
Engine Performance problem
1995 Isuzu NPR V8 Two Wheel Drive Automatic 119077 miles
Engine was running intermittently, Changed out computer, changed out distributor, new fuel pump,
did tune up.
Engine started up and ran great for about 15 seconds
and stopped. Turns over but will not start again.
Need help desperately as this truck is my livelyhood.
Appreciate you help.
did tune up.
Answer
Replied on June 11, 2009
Hi
Check for spark pull plug wire hold next to block crank spark ? blue/white 1/4 to 1/2 in.?
If spark spray carb cleaner into intake crank run for a bit?
Let me know
Thanks for donate
Also check engine light come on?
Thanks for your reply. I have tried your suggestion already. I am in the process of replacing the coil.
