starter replacement?
2000 INFINITI I30
TRE8MONK
Where is the starter located
Nov 11, 2014 at 10:10 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
The start motor is on the transaxle here is a sguide to walk you through the steps and diagrams below to show you how and where on your car.
Nov 11, 2014 at 10:12 AM
SAFETY9586
2001 Infiniti I30 6 cyl Automatic
where is starter located and how to replace it
Jan 12, 2019 at 5:59 PM (Merged)
FLEXANS
Located below Air intake filter housing and some wiring harnesses against the engine. After you remove the air filter housing and intake tube (removing battery 1st will help access), follow the positive battery cable to the starter coil.
Disconnect positive Battery lead from coil.
Remove the 2 bolts attaching the starter (15mm and 17mm).
Remove starter carefully to avoid damaging wiring
To install - follow reverse order
Be careful not to pinch any wires under mounting flange before tightening bolts. I had the engine mount sensor wire get pinched and it took out my ECM module.
CHRISK_518
The salesman at the store said it was really easy since the starter is on top just underneath my air filter box. I know where the air filter box is but, I'm unsure how to remove it the correct way. I know it would be easier to take it to a pro but funds are really tight! Need to do this one on my own.
  • 31,937 POSTS
Remove the air box if that improves access, disconnect battery and disconnect main cable at starter and unplug solenoid wire, unbolt starter and remove, ensure you have the radio pin if it is a security system.
2CP-ARCHIVES
  • 4,540 POSTS
what do i have to remove to get to the starter? must change ASAP.
IMPALASS
  • 3,112 POSTS
The attached is the only information the Mitchell 1 manual provides.
2CP-ARCHIVES
  • 4,540 POSTS
I have to replace the starter about every 6 months or so. What is causing this?
Jan 12, 2019 at 6:00 PM (Merged)
what kind of starter motor??
what happened when it would not start???
were they all under warranty???
did you inspect the flywheel for missing teeth??
DONLIE
  • 7 POSTS
just replaced starter 2 weeks ago. Since then my tach is working intermittently. Sometimes when I start the car it works fine...other times doesnt move at all. Tapping on cluster has no effect.
KHLOW2008
  • 41,814 POSTS
Starter has nothing to do with the tachometer. Signal for tachometer is throught the ECM. Check the ECM wire connector.
GADAY
I recently bought this car, and I have already had to replace the alternator. Now the starter is out. What all do you have to remove to access the starter?
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation Here is the info. you requested.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_42.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_13.jpg
Hope this helps.. Thanks for using 2carpros.com!
ZACKMAN
  • 4,202 POSTS
Disconnect negative battery cable. Remove air duct assembly. Remove starter mounting bolts. Disconnect battery cable from starter. Disconnect starter harness connector. Remove starter. To install, reverse removal procedure.
SHJ
my husband wants to change out the starter on my i-30. what does this entail? guess what i want to know is does he have to remove several parts to access the starter etc?
ZACKMAN
  • 4,202 POSTS
Just make sure that he disconnects the battery before working with electrical parts. The only part to remove is the air filter box assembly to get to the starter.
