won't start
2005 HYUNDAI TUCSON
170,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JONNYVAN14
Car won't start. Does turn over and there is fuel. Fuel relay switch is good. It just keeps cranking. No engine light. I was driving it and then came home and parked it. 20 mins later came outside and won't start.
Jan 13, 2014 at 8:46 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,351 POSTS
It sounds like the crankshaft sensor has gone out, but to be sure you will need to follow this guide first.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Apr 22, 2017 at 7:41 PM
GR8GY
hi. my car overheated and stalled on the side of the road. had the car towed back to my house. the battery died we charged it and now the car will not start it will cranks but just won't start .is there a reset button or do I need to take it somewhere
Apr 22, 2017 at 7:41 PM (Merged)
HMAC300
  • 48,601 POSTS
try resetting your antitheft unit it should be covered in your manual. we just fix them don't reset them
ANGELO 1699
Engine Performance problem
2005 Hyundai Tuscon 6 cyl Front Wheel Drive Automatic 120000 miles
This vehicle wouldn't start. No firing, etc. Never done it before. In the last month had occasional raw gas smell on start up. Mechanic checked it out next day, started fine repeatedly, no stored codes.This vehicle was bought new and had no problems ever before. Sure want to find out what is going on. Also has an aftermarket remote starter but it doesn't have fuel pump or starter kill feature.
BMRFIXIT
  • 19,053 POSTS
Was it checked for tune up ?
also should check for pending codes
if still no start check and suspect crank sensor
ANGELO 1699
I am not sure if the tune up was checked but it did start fine and no codes were found. What code would indicate crank sensor problem? Also I am really uneasy with this as nothing was found or fixed so how can I be confident it is good now?
BMRFIXIT
  • 19,053 POSTS
If engine was cranking but did not start
usually it sets codes( why it didn’t
to keep things simple )
some codes may need more time to show up as codes but PCM will fill them as pending codes
check for that would help in diagnosing the problem
I find it very strange that they didn’t check it for tune with that many miles
ANGELO 1699
I have had the regular scheduled maintenance done according to Hyundai's list. Admittedly it was done to keep the 100,000 mile warrantee in force but everything was done on schedule.
I have never heard about pending codes before but the garage where it was taken has been in business for over 25 years and has a very good reputation so I'd expect they would be familiar with pending codes.
The car is running fine again but nothing was fixed so I find it hard to rely on it.
BMRFIXIT
  • 19,053 POSTS
[quote:5d246c2294="Angelo 1699"]I have had the regular scheduled maintenance done according to Hyundai's list. Admittedly it was done to keep the 100,000 mile warrantee in force but everything was done on schedule.
The car is running fine again but nothing was fixed so I find it hard to rely on it.[/quote:5d246c2294]
ROSS WOODS
drove home and shut vehicle off. went out next day turns over but no start. can hear fuel pump working
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
TERRYHILL50
Electrical problem
2005 Hyundai Tuscon 6 cyl All Wheel Drive Automatic 125000 miles
I installed a new fuel pump, we know that its working, we can hear it run, but now we have no power to the injection fuse , and sensor fuse and no power to the main relay fuse. Please help, any advice would be greatly appreciated. thanks..Terry Hill
Find the fuel pump relay see pic below-swap it with a like one and see what happens-still the same find the white wire on the relay socket and check for power on it-Let me know we start here
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_relay_25.jpg
Apr 22, 2017 at 7:42 PM (Merged)
ANONYMOUS
  • 0 POST
has spark, fuel pressure, but won,t start just stalled and won,t run no more ?? stumped
ok, you need the last thing to run, compression. have it checked.
ANONYMOUS
  • 0 POST
Car won't start. Ran fine in the rain, came home parked it, next day wouldn't start. Turns over and lights all work, fuses ok, checked and looks like it might not be getting spark
Car has always run good. Please help, need car for work.
Thank you
KHLOW2008
  • 41,814 POSTS
Check the crank sensor. Water contamination to the connectors could have resulted in no sparks.
