Spark plugs removal
JJSTELM
  • 2009 HYUNDAI SONATA
  • 2.4L
  • 4 CYL
  • 118,000 MILES
I was watching your video on spark plugs for this vehicle. Is there anything I should unplug or detach that is electrical within the car before doing spark plugs? Such as a battery, sensors, etc. And if I disconnect the battery should I only take the negative off or the positive terminal as well? Just trying to be precautious. Thanks!
Thursday, April 25th, 2019 AT 1:05 AM
  • 52,797 POSTS
Good morning,
No special items to disconnect. No need to remove the battery cable as well. Here is a guide to help with diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Thursday, April 25th, 2019 AT 4:07 AM
CARLW
  • 2008 HYUNDAI SONATA
  • 90,000 MILES
What is the spark plug gap for the 2.4L Thanks
Friday, November 27th, 2020 AT 5:42 PM (Merged)
Hello the spark plug gap is - Gap 1.0 1.1 mm (0.0394 0.0433 in.) here is a guide that will help walk you through the service.
JESARAM
  • 39 POSTS
  • 2004 HYUNDAI SONATA
  • 180,000 MILES
I have a 2004 hyundai sonata with 180000 miles on it 5spd 4cyl. The problem it has is that ever time I accelerate I see electricity coming out of the plastic boot of my spark plugs. I replaced the plastic boot but now it sparks even more. What could be wrong? I appreciate any help. THANK YOU :)
Friday, November 27th, 2020 AT 5:43 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Were the spark plugs and wires replaced?
JESARAM
  • 39 POSTS
No I haven't. The problem is that it arcs at the top of the plastic booth to the side of the intake.
KHLOW2008
  • 41,814 POSTS
If you mean the plastic boot of the plug wire or ignition coil, when you have a bad wire, arcing would occur. Bad spark plugs could be the cause as well.
Friday, November 27th, 2020 AT 5:44 PM (Merged)
JESARAM
  • 39 POSTS
Would you recommend changing the wires and spark plugs? I appreciate your help. :)
JESARAM
  • 39 POSTS
Do you think it could be the coils on it?
KHLOW2008
  • 41,814 POSTS
Usually the wires are the ones to ail first and Have those replaced first and retest.
JESARAM
  • 39 POSTS
I have replaced the wires but no difference I also tried other coils but it still keeps arcing and now when I turn my A/C on it starts to shake.
KHLOW2008
  • 41,814 POSTS
Have you replaced the spark plugs?
JESARAM
  • 39 POSTS
No I haven't but I took them out and they seem to be fine. But I will
KAWANEE
  • 2003 HYUNDAI SONATA
Electrical problem
2003 Hyundai Sonata 6 cyl Two Wheel Drive Automatic
How much does it cost to replace the spark plugs and wires on my 2003 Hyundai Sonata?
Labor rate per hr. varies with location could range from $70-$130.00 per hr. See quote
https://www.2carpros.com/forum/automotive_pictures/12900_spark_plug_wires_and_plugs_1.jpg
KHLOW2008
  • 41,814 POSTS
Ok
Good luck
WGORHAM
  • 4 CYL
  • FWD
  • 138,000 MILES
Where are the spark plugs located on the car. How do you replace them?
Its under the coil and plug wires-see below
https://www.2carpros.com/forum/automotive_pictures/12900_sparkplugs_2.jpg
YESI OLIVAREZ
  • 2.4L
  • 4 CYL
  • 65,000 MILES
How do I replace the spark plugs and the spark plug boots?
STEVE W.
  • 13,021 POSTS
You shouldn't need to replace the plug boots unless they are damaged or the wires are bad.
To replace the plugs, start at one end of the engine, pull up on the plug wire boot to remove it from the plug, then use a spark plug socket and extension to remove the plug. Examine the plug for any problems. Now check the gap on the new plug, adjust as required (the plug number and gap will be on the emissions sticker under the hood) install it into the head and tighten it down. If the boot is damaged you simply follow that wire back and remove it, select the same sized wire from the new set and install it in reverse of the way you removed it.
