2CarPros - Car Questions & Answers
2002 Hyundai Santa Fe Repair Question
Topics covered: Dent, Engine, Tire.
Asked on January 21, 2010
2002 Hyundai Santa Fe Serpentine belt removal
Engine Mechanical problem
2002 Hyundai Santa Fe 6 cyl Two Wheel Drive Automatic 120000 miles
Hello!
How is the spring loaded belt tensioner moved so that the belt can be removed? Neither the Chilton's manual or the instructions on Hyundai's site describe this enough or accurately. Hyundai's site indicates to use a 16mm spaner (sic). The Chilton book says to use a long ratchet or breaker bar. There appear to be only 2 bolts holding the tensoner assembly to the engine, but it seems like I may have only to push the pulley downward to loosen the tension. I can't see how to do this without leveraging against another pulley and/or the belt itself, risking damage. This is a 2.7L V6. Any help would be truly appreciated!
Thank You - Lawrence
Avatar Asked by Lawrence2010
Answer
Replied on January 21, 2010
Hi Lawrence,
Thank you for the donation.
The tensioner lever is turned clockwise to release the tension to remove the belting.
At the 3 o'clock position of the tensioner is a square block jutting out. Use the 16 mm open end spanner to lock onto it as a leverage point.
http://www.2carpros.com/forum/automotive_pictures/192750_DriveBelt02SantaFe27LV6Fig03_1.jpg
Tiny Answered by KHLow2008 (expert)
39,832 answers provided
http://www.2carpros.com/forum/automotive_pictures/467674_Tension_Arm_1.jpg
Thank you for the quick response. The block at 3 o'clock is not nearly as square as that in the diagram. In the uploaded photo, you can see how it doesn't even look designed to take a spanner - the upper side is curved. It's also about 14 1/2 mm wide. I must be missing something basic here: is the entire arm and pulley supposed to be rotated clockwise to reduce the tension enough to remove the belt? I'm assuming that 'tensioner lever' is the entire arm with the pulley at the end.
Thanks Again - Lawrence
Tiny Response from Lawrence2010
1 question asked
Replied on January 22, 2010
The arm with the pulley should be turned clockwise. Our database does not have any other diagrams for the tensioner and personally those that I have dealt with either have a bolt at the pully side or an indent for holding a box handle to use as leverage point.
At the bottom end where pulley bearing is attached I see a small indent in your picture. Is it suqare or round? If it is square or hexagonal, then that would be the best point to attach a wrench to turn the arm.
Alternatively, are the 4 indents at center of arm able to provide any grip for some tools?
Replied on January 23, 2010
A poster in alt.autos.hyundai cleared things up. There's a square at the end of the tensioner arm right in front of the pulley made for a 3/8" ratchet. After placing the square of the ratchet there I needed only to apply my body weight to easily remove the belt. The Hyundai site and the Chilton's manual are both incorrect, and don't even depict the ratchet hole. Thank you for all your help - I had never worked with a tensioner arm before and am a little embarrassed that I didn't understand what I needed to do. Thanks Again.
1 question asked
Replied on January 24, 2010
Glad that you have resolved the problem.
There is nothing to be embarassed about as for all things there are always a first time.
Have a nice day.
Replied on March 30, 2010
Would either of you happen to know how to remove the bolts to be able to replace the serpentine belt tensioner?
Tiny Answered by kallosue
0 questions asked
The diagram shows the tensioner holding bolts, one on either of the tensioner. After removing the belt, you can proceed to remove the tensioner.
Replied on July 29, 2010
The illustration posted earlier is no help in identifying how to release the tension. The wrench is applied to the bottom of the tension arm, NOT to that little tab at the top of the arm assembly.
http://www.2carpros.com/forum/automotive_pictures/556092_DriveBeltSantaFe27LV6_2.jpg
Tiny Answered by Old-n-Grey
0 questions asked
Replied on July 31, 2010
Hi Old-n-Grey,
Sorry you got it wrong.
Along the post we mentioned a 3/8" ratchet holding point. The red shaded area is where the socket or ratchet handle can fit to turn the tensioner arm.
http://www.2carpros.com/forum/automotive_pictures/192750_DriveBelt02SantaFe27LV6Fig03_2.jpg
I regret bothering to sign up just to set this issue straight. But I was NOT wrong.
The later information about a 3/8" ratchet hole only applies to later models of the tensioner.
Anyone relying upon your "red shaded area" will be lost if they have the early version and attempt to use either the first descriptions posted above or your reference.
0 questions asked
