changing the serpentine belt
2004 HYUNDAI SANTA FE
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARLINCOLLINS
need to change the serpentine belt?
Nov 29, 2009 at 3:52 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Here is a guide to help walk you through the steps with a guide link to show you how on your car
https://www.2carpros.com/diagrams/hyundai/santa-fe/2004
and
https://www.2carpros.com/articles/replace-serpentine-belt
Nov 29, 2009 at 11:58 PM
HYUNDAI DRIVER
I've been having a squeaking noise, I believe it's coming from my front passenger side. I thought it was coming from my brakes, since I hear it when I brake. But I'm hearing the squeaking noise when my car is in motion. My dad, who lives in another state, believes it may be the fan belt.
May 11, 2020 at 1:40 PM (Merged)
  • 110,190 POSTS
It could be a couple things. Do you hear it when the car is stopped or only when you are moving? Let me know.
JOANIBUCK
Trying to find out how to loosen the drive belt so that we can replace the alternator?
  • 110,190 POSTS
Take a look at this page. It identifies where all adjusters and belt tensioniers are located for all engines in your type of vehicle.
https://www.2carpros.com/car_repair_information/year/2001/make/hyundai/model/santa_fe/2001_hyundai_santa_fe_drive_belt_routing_diagram.htm
Let me know if it helps.
MARK ELLIS
Noises problem
2004 Hyundai Santa Fe 4 cyl Four Wheel Drive Automatic
A friend's serpentine belt is squeaking. Is it loose or is the noise from the tensioner? How does it get adjusted? Thank you.
May 11, 2020 at 1:41 PM (Merged)
  • 110,190 POSTS
Hi:
Some of these vehicles have automatic temsioners that can go bad, others need to be adjusted. Check to make sure everything is tight. Check the tensionier to make sure it is working and any manually adjusted belts need to be inspected for tightness.
Let me know what you find.
