fuel filter to be installed
2010 HYUNDAI GETZ
64,000 MILES
PONOANE
my question is i sent my car for fuel filter to be installed and the person install the new Hyundai part but the car couldn't start and he removed it again reinstall the old one and the car works. what seems to be the problem ,because the new filter did pump the petrol right but the car couldn't start and i notice a cash up hot of an energy but not showing on the alerts inside the car may be im to afraid of what could happen to my car help me. Can i still install the new fuel filter or the filter is faulty?
Dec 19, 2012 at 8:08 AM
  • CAR REPAIR CONTRIBUTOR
Im not sure whats going on because this car doe not have a fuel filter per say it has a fuel strainer in front of the pump here are diagrams to help you see what you are in for when replacing the pump and filter.
Cheers
Dec 19, 2012 at 9:59 AM
LEONORA
Where is the fuel filter situated?
Sep 12, 2019 at 12:23 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is under a panel under the back seat of the vehicle. Screws out of the top of the tank with the fuel pump and sender unit. Replace filter making sure you swap over all the O rings and seals and that everything fits okay. Be careful not to damage sender unit. If you miss any seals or O rings or anything doesn't seat properly the car will not start, so make sure you are very thorough when you install the new filter.
This guide will help you see with diagrams below to show you on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
ROLAND420
I have a 2005 Hyundai Getz gl 1.3 I have had a service recently changed the petrol filter & petrol pump. when I drive for about 5-10kms the car sputters loosing all power and acceleration and comes to a halt. I have to pull over for 10mins
  • 31,937 POSTS
Check fuel pressure, check for any unresolved fault codes, not all codes will set a check light, start here.
2CP-ARCHIVES
  • 4,540 POSTS
Hi when i first start up and drive off the car travels as normal but then loses all power (motor only) when going up a hill . This does not happen all the time and we have replaced fuel filters etc . The car is an automatic. Once pulled over the car starts again and drives off as normal
thks
KHLOW2008
  • 41,814 POSTS
Is the Check Engine Light showing when this occurs?
Did you check the accelerator cable to see if there is too much slack in it?
Ensure the floor mat is not too thick and afffecting the gas pedal travel.
