where is the fuel pump relay
1998 HYUNDAI ACCENT
156,740 MILES • 4 CYL • FWD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
Where is the fuel pump relay located?
Oct 14, 2010 at 11:25 PM
2CP-ARCHIVES
  • 4,540 POSTS
The fuel pump relay is under the dash on drivers side here is a guide to help you test it with a diagrams below to show you where it is.
Oct 14, 2010 at 11:27 PM
R RUMSEY
where is the fuel pump relay located
Dec 11, 2018 at 4:29 PM (Merged)
  • CAR REPAIR CONTRIBUTOR
The relay is located on the left side of the steering wheel behind the diagnostic connector there is also a pocket below the connector, take the pocket out of the dash, the relay will be the middle one top row.
RFOX1258
2000 hyundai accent 4 cyl front wheel drive need to know where fuel pump relay is located and what it looks like
Dec 11, 2018 at 4:30 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Its under the hood in the fuse and relay box
VIDBOX100
  • 16 POSTS
Does fuel pump relay operates through out the engine running. can engine + out side temperature cause relay problems, by increasing resistance due to temperature rise.
WRENCHTECH
  • 20,761 POSTS
The relay energizes for 2 seconds when the key is first turned on. The weather can effect any electrical component but it's not likely.
JESUSBZ
crank but wont start ,,need to know , does the computer control the fuel relay and does it control the coil packs too.have power at fuel pump , have power at relay.when i open the relay and place a screw driver to touch the relay manueley the fuel pump works,also idont have power at the coils.thinking of replacing computer does that make sense ? already replaced fuel pump,fuel pump relay,ecm relay,and spark plugs. thanks...
  • 110,190 POSTS
Yes, those items are controled by the computer. However, I believe your car has an Auto Shut Down (ASD) that will kill the fuel pump and the ignition.
GIJACK
My Grand Daughter had a fender bender today and her car will not start. I injected a small amount of starter fluid and the car started for a few seconds, telling me that the inerta switch must have kicked off.
Where is he fuel pump inerta switch on a 2000 Accent?
Thank you
Jack
You don't have an inertia switch
If you can hear the fuel pump come on, when you turn key to run position-check the fuel pressure with a fuel pressure gauge to rule out the fuel pump-
JESUSBZ
having problems with fuel, with small scew driver after i opened the fuel pump relay cover i touched relay the fuel pump worked, have changed fuel pump relay,changed ecm relay,changed fuel pump.no fuel related codes. also found no spark from coil packs related unknown.all other fuses are good.have power at fuel pump and groud,relay is good,have power and ground.do ineed to change coil packs.also spark plugs changed.with fuel pump relay does not make noise with key on.
You have a complicated problem here-fuel pump relay not energizing could be the computer controlled of the fuel pump relay and also the coil drivers in it. Have the computer tested.
