2CarPros - Car Questions & Answers
2006 Hummer H3 Repair Question
Topics covered: Terminal, Battery, Four wheel drive.
Asked on July 27, 2010
2006 Hummer H3 blower motor
Electrical problem
2006 Hummer H3 6 cyl Four Wheel Drive Automatic 120000 miles
When I connected the blower to the battery it worked fine. After several more test I think I lost the ground. I momentarily grounded the one terminal on the fan harness and the fan started to run. What would you recommend to repair this?
Avatar Asked by ktyson
Answer
Replied on August 5, 2010
Pull the connection at the resistor. If it is burned, replace the resistor and conenctor/terminal. There is also a harness available with that connector, it is a bit more in price, but is plug and play.
Tiny Answered by factoryjack (expert)
4,285 answers provided
