Fuel pump and filter location
JULIAN
  • 2004 HONDA CRV
  • AWD
Location of the fuel filter on Honda CR-V
Friday, July 15th, 2011 AT 5:20 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
This car has what they call a lifetime fuel filter even though sometimes they can plug up. The fuel filter is located in the fuel tank. Which will need to be remove to get the filter out. Some cars have a trap door for the fuel pump and filter and it looks like you car is one of them but if not here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Here are some diagrams to help you see what I am talking about and how to do the job on your car. (below) Please let us know if you need anything else to get the problem fixed.
Thursday, November 16th, 2017 AT 12:02 PM
EDEJESUS
  • 2001 HONDA CRV
  • 4 CYL
  • 4WD
  • 113,000 MILES
Engine Mechanical problem
2001 Honda CRV 4 cyl Four Wheel Drive Automatic 113000 miles
I would like to know where is the fuel filter located
Thursday, November 16th, 2017 AT 12:02 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi edejesus,
Right rear corner of Engine Compartment, in front of EVAP canister.
CATTIELANE
  • 2002 HONDA CRV
  • 4 CYL
  • 4WD
  • 115,000 MILES
Engine Performance problem
2002 Honda CRV 4 cyl Four Wheel Drive Automatic 115000 miles
I need to know where the fuel filter is located.
Thank you
KHLOW2008
  • 41,815 POSTS
Hi cattielane,
Fuel filter is located in the fuel tank together with the fuel pump.
GRIMBO
  • 2002 HONDA CRV
  • 4 CYL
  • AWD
  • MANUAL
  • 48,000 MILES
Where will I find the fuel filter on my crv
Thanks. G
Wednesday, July 17th, 2019 AT 7:32 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Not my 04 ex crv the fuel filter is in the tank not easy accessible.
GRIMBO
Would that be the same place on a british crv
OBXAUTOMEDIC
  • 3,711 POSTS
It should be
SINISA
  • 2002 HONDA CRV
  • 4 CYL
  • FWD
  • 120,000 MILES
How to replased fuel filter
Service and Repair
Notes
The fuel filter should be replaced whenever the fuel pressure drops below the specified value (270 - 320 kPa, 2.8 - 3.3 kgf/sq.cm, 40 - 47 psi) , after making sure that the fuel pump and the fuel pressure regulator are OK.
Remove the fuel pump.
https://www.2carpros.com/forum/automotive_pictures/12900_filter_3.jpg
Remove the fuel filter (A).
Install in the reverse order of removal with a new base gasket (B) and a new O-ring (C), then check these items:
When connecting the wire harness, make sure the connection is secure and the terminal (D) is firmly locked into place.
When installing the fuel gauge sending unit (E), make sure the connection is secure and the connector is firmly locked into place. Be careful not to bend or twist it excessively.
DDHUNTER45
  • 2002 HONDA CRV
  • 4 CYL
  • 118,000 MILES
My 2002 Honda CRV 4wd shuts down when I come to a stop. It no longer idles. I can easily start it again and as long as I keep the RPMs up, the car functions fine. Is this a fuel pump issue?
Saturday, June 6th, 2020 AT 12:06 PM (Merged)
Clean out the idle air control valve, test the throttle position and manifold absolute pressure sensors-to include a fuel pressure check-
HONDA TECH 1818
  • 536 POSTS
Replace the IAC valve.
MOUNTAINMOBILEMECHANIC
  • 2001 HONDA CRV
2001 Honda CRV 6 cyl All Wheel Drive Automatic
Hey how long does it take to do this, you have to drop the tank I assume right?
BLACKOP555
  • 10,371 POSTS
With vehicle lift you can get it done in 1 hour, without the lift suspect a 2 hour job.
SINISA
  • 2002 HONDA CRV
  • 4 CYL
  • FWD
  • 120,000 MILES
How to cheng fule pump
Fuel Pump/Fuel Gauge Sending Unit Replacement
Special Tools Required
Fuel sender wrench 07XAA-001010A
1.Relieve the fuel pressure.
2.Remove the fuel fill cap.
3.Fold the rear seats forward, and pull back the carpet to expose the access panel.
https://www.2carpros.com/forum/automotive_pictures/12900_fp1_29.jpg
4.Remove the access panel (A) from the floor.
5.Disconnect the fuel pump 5P connector (B).
6.Disconnect the quick-connect fitting (C) from the fuel tank unit.
https://www.2carpros.com/forum/automotive_pictures/12900_fp2_3.gif
7.Using the special tool, loosen the fuel tank unit assembly locknut (A).
https://www.2carpros.com/forum/automotive_pictures/12900_fp3_5.jpg
8.Remove the locknut (A) and the fuel tank unit.
9.Remove the fuel filter (B), the fuel gauge sending unit (C), the case (D), the wire harness (E), and the fuel pressure regulator (F).
10.When connecting the fuel tank unit, make sure the connection is secure and the suction filter (G) is firmly connected to the fuel pump (H).
11.Install the fuel tank unit in the reverse order of removal with a new base gasket (I) and new O-rings (J). Be sure to check these items:
*When connecting the wire harness, make sure the connection is secure and the connector (K) is firmly locked into place.
*When installing the fuel gauge sending unit, make sure the connection is secure and the connector is firmly locked into place. Be careful not to bend or twist it excessively.
*When installing the fuel tank unit, align the marks (L) on the fuel tank (M) and the fuel tank unit (N).
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
GARYT
  • 2002 HONDA CRV
  • 4 CYL
  • MANUAL
  • 60,000 MILES
How do I locate, clean or replace the fuel filters?
Tuesday, June 23rd, 2020 AT 1:44 PM (Merged)
