2CarPros - Car Questions & Answers
2000 Honda CRV Repair Question
Topics covered: Clutch, Transmission, Clutch pedal.
Asked on January 9, 2010
2000 Honda CRV Clutch pedal seems too loose
Transmission problem
2000 Honda CRV 4 cyl Front Wheel Drive Manual 155,00 miles
Just recently we have noted that there is quite a lot more play in the clutch pedal than before. It seemed like it briefly returned to the usual amount of play, but is now excessive....about 50-60% of the available excursion of the pedal before it disengages the transmission when pushing the pedal in. There are no new noises, and the car still shifts easily, once the clutch is engaged. Does this sound like a problem with the linkage (could have slipped d/t age, cold weather)? Clutch fluid low? Possibly the whole clutch is on the way out?
Thanks in advance for any help.
tombohanon
tombohanon@hotmail.com
Avatar Asked by tombohanon
Answer
Replied on January 11, 2010
Hi tombohanon,
Do you mean the pedal has to be released more than usual for the transmission to engage?
Tiny Answered by KHLow2008 (expert)
39,944 answers provided
Replied on January 12, 2010
Hi again,
No, its not so much of a release problem as an engagement problem. Normally, I have to push the clutch pedal in about 25% of the way for the clutch to start to work and change gears (even though still pushing it all the way to the floor as one should), and now I have to push it about 60% of the way in before the transmission starts to disengage and I can shift.
Does that make sense? Sorry, but my mechanical skills and basic knowledge are pretty limited.
Thanks again for the help!
Tiny Response from tombohanon
1 question asked
The clutch pedal is now lower than prevuiously and possible causes are a faulty ckutch hydraulic system. Check the clutch fluid level and if low, check the master and slave cylinder for leakages.
