P0420 code
PALERO
  • 2002 HONDA CRV
  • 4 CYL
  • 4WD
  • 109,000 MILES
What sensor do I have to replace with p0420 code my car
Wednesday, February 16th, 2011 AT 12:19 AM
This code Catalyst System Efficiency Below Threshold (Bank 1) is because the catalytic converter is worn out here is a guide to help walk you through the replacement with diagrams below to help you with your car.
https://www.2carpros.com/articles/catalytic-converter-replacement
Wednesday, February 16th, 2011 AT 12:27 AM
JOEY LITTLE
  • 1999 HONDA CRV
  • 4 CYL
  • AWD
  • 150,000 MILES
I have a code p0420 that says catalyst efficiency below threshold(bank 1). What is this?
Wednesday, February 13th, 2019 AT 8:10 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Usually a faulty O2 sensor will throw this code. Need to check your oxygen sensors. Follow the link below to learn how to test an oxygen sensor.
https://www.2carpros.com/how_to/how_to_test_oxygen_sensor.htm
If sensors are OK, need to flow test the catalytic converter..
Thanks for using 2CarPros.com!
EGUZMAN72
  • 1999 HONDA CRV
  • 4 CYL
  • 4WD
  • 180,000 MILES
What does this code mean? I think it needs a regular maintenance but I am not sure.
KHLOW2008
  • 41,814 POSTS
Hi eguzman72,
P0420 = Catalyst efficiency below threshhold.
Usually this means the catalytic converter is bad. It is not a regular maintenance item.
