timing marks
2001 HONDA CIVIC
1,000,000 MILES • 4 CYL • FWD • MANUAL
PAULKARYDAS
Can I get the timing marks 2001 honda civic 1.7 please?
Mar 31, 2011 at 10:49 PM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Here is a guide and the diagrams below so you can see how the job is done.
https://www.2carpros.com/diagrams/honda/civic/2001
Mar 31, 2011 at 10:57 PM
CLUMSY
Dealer tells me I need to replace the timing belt now because of the age of my car and not the mileage. Is this true? Should it be changed now instead of at the 100,000 mile mark?
Thanks
Oct 8, 2018 at 5:27 PM (Merged)
  • 31,937 POSTS
HI there,
Thank you for the donation,
Most manufacturers will give a mileage or time frame to replace the timing belt. If your dealer has advised this is now due for your car, i would do it. These engine are interference engines, that is valves will strike pistons if the belt fails, the cost is horrendous to repair these engines, i would change the belt, it's call preventive maintenance.
Mark (mhpautos)
TOPGUN1226
  • 29 POSTS
I have to agree. I'm at around 82,500 miles right now - I plan on doing the timing belt and waterpump on my next yearly visit to the Honda dealer in August... It's preventative maintenance, and unfortunately, it's one of those things you just "don't know" it's going to go.
Nobody in my family has bothered to change their timing belts, and they didn't fail as long as they've owned the car. So, it's a peace-of-mind thing.
LEGITIMATE007
  • 5,121 POSTS
unfortunately i waited too long on one of my vehicles. the price of the repair was so high that it became one of the reasons why i went to school to be an auto technician. I TELL YA MY CHAIN SLIPPED AND BENT THE VALVES. UGLY SITUATION. THE ONLY THING I WOULD PROBABLY DO DIFFERENT THOUGH, IS : IF YOUR CAR IS NOT UNDER WARRANTY, I SUGGEST THAT YOU SHOP AROUND FOR LABOR PRICES, DEALERS ARE VERY EXPENSIVE
TOPGUN1226
  • 29 POSTS
My dealer here in NJ said it'd be 600 for just the labor and the new timing belt... More if I wanted to do the water pump.
Local shops near by seem to be around 100 bucks cheaper, for 100 bucks I'd personally rather have Honda do it... The local shops nearby seem to get a kick out of employing 16 year olds to work on peoples' cars.
LEGITIMATE007
  • 5,121 POSTS
well yeah, they don't have to pay them anything lol
KHANSSEN
I recently had some routine maintenance work done on my car - timing belt replacement, replaced seals, getting carbon out of the engine, etc.
Now that I have my car back, it's very squeaky. It squeaks on slow turns, but the most alarming thing is that no matter how fast I'm driving, about every 15-20 seconds, the car does a little squeak and at the exact same time, loses its forward acceleration for a split second. It feels like it slows slightly, and then after the squeak, it picks right back up.
It's most noticeable when I have the car on cruise control, but it's happening without it as well.
Could some of the repair work have caused this problem?
KHLOW2008
  • 41,814 POSTS
Hi khanssen,
I believe the power steering and AC belt has not been adjusted properly. GEt back to the shop which did the job to have it rectified. Hope the crankpully is correctly torqued.
GTY75007
what can cause a 2001 honda civic not to start after timing belt was replaced?
double checked tdc and timing marks...
WRENCHTECH
  • 20,761 POSTS
What was the condition of the old belt. Had it broken or jumped time before you replaced it?
SYLVIANGOCDANG
My Honda Civic has about 84,000 miles on it.. I'm just wondering if i should change the timing belt and have it tuned up? I checked and the cost is around $500. Would that be a reasonable price?
Thank you!
Oct 8, 2018 at 5:28 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi SylviaNgocDang,
Labor time is between 2.5 to 3.5 hours depending on whether oil seals are to be replaced.
Parts cost is about $ 100.
$ 500 inclusive of tuneup and servicing seems reasonable depending on where you are located and local conditions.
Recommended timing belt replacement period is 105 k miles under normal conditions. Under extreme temperature, over 110 degrees F and under -20 degrees F recommended to replace at 60k miles.
SYLVIANGOCDANG
[quote:2d3d2441e0="KHLow2008"]Hi SylviaNgocDang,
Recommended timing belt replacement period is 105 k miles under normal conditions. Under extreme temperature, over 110 degrees F and under -20 degrees F recommended to replace at 60k miles.[/quote:2d3d2441e0]
Hi again, Thanks for the reply.
I'm currently in San Diego, California. I don't think the weather is that extreme where i have to change the timing belt at 60K miles. My car right now has 84K miles so tuning up is recommended right? I'm thinking on having it done asap since i commute too much for school and work.
About chaning a new timing belt, I should wait till 90K too 100K miles? If so, then the tune up fee wouldn't be that much correct?
Oct 8, 2018 at 5:29 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi SylviaNgocDang,
Tuneup is not that important for vehicles nowadays. The things that you need to check would be the spark plugs and oil replacement.
At 84 k miles it should last you up to 100k without problem but I forgot to mention the time frame is 84 months so I would recommend that you get it replaced at 90 k miles max, to be on the safe side.
SYLVIANGOCDANG
[quote:42b4d9184e="KHLow2008"]Hi SylviaNgocDang,
At 84 k miles it should last you up to 100k without problem but I forgot to mention the time frame is 84 months so I would recommend that you get it replaced at 90 k miles max, to be on the safe side.[/quote:42b4d9184e]
Thank you so much, CarPros!
I'll have the oil changed tomorrow then.. Have a great weekend and i'll get back to you guys to see how it turns out..!!
OGBABYDOLL
At what mileage do I need to replace the timing belt and water pump?
F4I_GUY
  • 3,302 POSTS
Severe maintenance is 60,000mi. Regular maintenance is 100,000mi
OGBABYDOLL
Thank you for helping me out with my question. Truely appreciated! Have a great day!
D. MOORE
I have owned my Honda Civic ever since the 50,000 mile mark. I have had little to no problems with the car. I now use the car as a work vehicle. I have heard different opinions on how critical changing the timing belt is. The change of the timing belt has been quoted to me and seems relatively expensive. Is this something I could get by without doing at this point, since there are no issues?
Oct 8, 2018 at 5:32 PM (Merged)
F4I_GUY
  • 3,302 POSTS
As the vehicle ages, the belt because more worn out. If the belt snaps, you will need a new engine.
Replace the timing belt a.s.a.p.
FOOLISHQUESTION
I bought this car last year with about 153k miles on it. I recently had a mechanic look at it, who said it seemed fine, but when had the timing belt been replaced, since--if it goes--the valves go with it, and then the car wouldn't be worth much of anything.
Unfortunately, I bought it from a dealer who didn't give me any record of maintenance.
Should I replace the belt now? The mechanic estimated approximately $700. A fair price?
BLUELIGHTNIN6
  • 16,542 POSTS
Since you don't know when it was last replaced, yes it would be a good idea to replace it now. However, $700 seems a bit high for replacing your vehicle's timing belt.. unless they are doing more to it than just the belt itself. Below is an estimate..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_650.jpg
CLEOBABY
I have a 2000 civic ex with approx. 103,000 miles on it. I am going to replace my timinig belt, but many dealerships I have called reccomend to replace the 4 driving belts and fan belts as well. Can anyone tell me what these 4 drive belts are called?
Jan 5, 2020 at 5:43 PM (Merged)
BRUCE HUNT
  • 3,754 POSTS
They are serpentine belts. Probably an alternator belts, power steering belt and A/C belt. There might be an additional belt inside the timing cover besides the timing belt itself.
RJDOPEST
When my car comes to a stop, whether at a stop light/sign, or coming off the freeway ramp, my car seems like it will die but does not?
KHLOW2008
  • 41,814 POSTS
Hi rjdopest,
Seems the idling speed is too low and I would suggestcleaning the throttle body and IAC valve to stabilise the idling.
88BRONCO
Engine Mechanical problem
2000 Honda Civic 4 cyl Front Wheel Drive Manual
My good friend just threw the timing belt on his 01 civic at 126K miles and our car (2000 civic) is at 116K. Our question is, are either of our engines interference engines??? I'm doing my belt now before I'm stuck like him, but need to know if I should even start on his or just get a new head for it and go from there??? this is a high octane web-site thanks for all the answers...
KHLOW2008
  • 41,814 POSTS
Hi 88bronco,
It should be a on interference engine but then again it does not mean that it cannot be damaged.
It will depend on the situation when the belt gave way.
Low engine runnig speed normally don't cause any problem but when at high speed, the valves might not be closing fast enough not to interfere.
Check the valve clearances to see if any are excessive would give you an idea if they had been hit.
PLAMPLEY
Engine Performance problem
1997 Honda Civic
How do you remove the timing belt tensioner on a 1997 Honda Civic LX?
Jan 5, 2020 at 5:44 PM (Merged)
F4I_GUY
  • 3,302 POSTS
by removing the 14mm nut.
PLAMPLEY
[quote:24db1900a6="F4I_guy"]by removing the 14mm nut.[/quote:24db1900a6]
The bolt is extremely tight. Feels like I'm stripping it to remove it. Is this normal?
