AC - no cold air
GOOGO
  • 1998 HONDA CIVIC
Air Conditioning problem
1998 Honda Civic 4 cyl Front Wheel Drive Automatic
test done to air cond system.
low pressure 40 to 50 llbs
high presure 300 lbs.
no cold air at all
low side hose is not cold at all
if I put 450 llbs of pressure then I get some cold air but the comprressor is binding and tthe rpm drops on the engine , so I had to discharge some freon. Again 300 lbs on the high side and 45 lbs onthe low side. Help
Wednesday, July 29th, 2009 AT 4:57 PM
TED-E-DEE
  • 109 POSTS
Ck. Hot/Cold control knob, pull it off & ck. center 1/2 moon to see if broken. Ck. Hot/Cold cable for defects. Ck. Hot/Cold valve under hood to see if seized. It is near firewall where hoses come out of heater core.
This guide will help us fix it
Wednesday, July 29th, 2009 AT 8:43 PM
TED-E-DEE
  • 109 POSTS
There is a themostatic switch in the Evaporator. If other components are o.K, have it checked by a Honda tech.
Friday, July 31st, 2009 AT 12:16 AM
MICROARMOR
  • 1998 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 150,000 MILES
1998 Honda Civic LX manual transmission
About 3 years ago during the summer I drove over a railroad track with the AC on. I didn't hit the tracks hard, but they are elevated a bit so it was enough for a light and normal jostle. I heard a reasonably loud clunk-clunk noise. It wasn't the bump noise of the track, but a different noise just milliseconds after. From that point on the AC was dead. In my civic, when I normally turn on the AC when it works properly, you can feel the compressor / clutch engage and the load on the engine. Now, I can still hit the AC button on the dash and the little green light in it will come on, but the ac never engages and I just get ambient temperature air blowing. Just today, I decided to do something about it. I tested the pressure and the refrigerant is properly pressurizing the system. No leaks. When the car runs, I can see the belt rotating fine over the compressor wheel and that isn't seized up. I checked the related fuses and they are OK. I fed a positive wire I rigged up to the wire coming off the compressor and I get a small spark, but the clutch does not engage. Now I'm thinking it is the clutch or the compressor or both. I'm guessing that is what I need to change. I see it online for auction for about $250 delivered with a dryer and o rings and oil. So, A) should I just replace this next. B) I assume legally I need to get it evacuated, so that's OK. C) after I put the parts back on and if I did it right, do I need to just go to a pro and get it evacuated and charged and then I'm done? If I can get away with not depressurizing the system and just change a clutch, that would be great but I don't know for sure if it will solve the problem. Thanks.
One more thing. I can't tell if the inner part of the clutch is spinning or not due to the location of the compressor. It's pretty far down there and up close to the front left wheel. If necessary, I guess I can pull the wheel off and start pealing back the shrouding between the wheel and the engine compartment.
Saturday, June 20th, 2020 AT 11:00 AM (Merged)
  • 31,938 POSTS
Hi there,
Thank you for the donation.
Thank you for all the information in your question, that is a big help, basically what I feel is going on here is that the clutch has failed, even if the comp was seized solid the clutch should still engage with the hot wire attached, as nothing is happening I would myself, be replacing the clutch assembly, now this is not hard but there is a special puller required to remove the clutch assembly off the compressor shaft, I would get an A/C tech to do this so there is no chance of damaging the shaft or the shaft thread.
Mark (mhpautos)
MICROARMOR
Thank you for the reply. I'll look into seeing if I can afford to get a pro to fix this. I did get one quote a while back and it was $650 US to replace the clutch to $1500 for the whole system. That seems significantly overpriced for the work to me. If I don't get a decent quote, I'll do it myself.
  • 31,938 POSTS
Let me know what the next quote is and I will see if it is about what you should be paying for that work, I will need to know exactly what they will be doing.
Mark (mhpautos)
LROGERS8932
  • 1998 HONDA CIVIC
I have a 98 Honda Civic EX with about 70,000 miles on it and I am having trouble with my AC. Whenever I turn on the AC it makes a loud noise by my glove compartment and doesn't go away unless I turn off the AC. The AC blows cool air, but it is just so noisy. What can be the problem? Somebody told me it can be the compressor, or condenser? Can you please help me, thank you.
FISHERMAN
  • 938 POSTS
Hello !
It is making the same noise when you turn on just the warm air?
(Just the blower)
If its making noise still and if the noise come from the glove compartment the problem its the Blower motor.
Check if your car is equipped with cabin filter. Could be that the filter got caugh for the blower and causing that noise, or the squirrel cage missaligned.
Good Luck and let us Know!
SARATH
  • 1998 HONDA CIVIC
I own a 1998 Honda Civic, 81000 miles. The Air conditioner blows hot air and shows no sign of cooling down. The heater was working fine during winter, but the cooler is giving me a hard time this summer.
Is there anything I can check before taking the car to a mechanic? I bought this car about a year ago when it had 71000 miles. I have never changed the coolant or done any service on it other than the regular oil changes.
Kindly advise.
Thanks,
Sarath
Saturday, June 20th, 2020 AT 11:01 AM (Merged)
Have the freon check maybe its leaking somewhere.
HONDACIVICPROBLEM
  • 1998 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 240,000 MILES
Three or four weeks ago I put two cans of artic freeze ultra synthetic r-134a in my wife's civic. The ac worked ok if it was a cool cool day but barely cut it if its hot out. The last couple of days it been in the 90s so I decided to put one more can in. After most of the can went in to the system the engine start shuddering and almost stalling. The a/c pump will kick on and off. If I shut the a/c off it runs fine. When I took it for a test drive and turned the a/c it would turn on for a sec then shut off again causing a sudden drop in power. Is it possible to put to much refrigerant in the system?
  • 31,938 POSTS
Yes, you can, the correct full charge is 1.38 Lbs or.8Kg of refrigerant, you will have to get the system vacuumed down, checked for leaks and the correct volume of refrigerant added.
Mark (mhpautos)
SGTACKLEY
  • 1998 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 64,000 MILES
I have a 1998 honda civic with 64000 miles on it and the air conditioning was working fine like its supposed to now the blower only works on high and most of the air comes out on passenger side under the glove compartment what could cause this. Thank you for any assistance.
KHLOW2008
  • 41,815 POSTS
Hi sgtackley,
The blower motor working only at maximum speed normally is due to a faulty fan motor resistor. Check if the blower resistor is broken for the 1st to 3rd speed.
The air coming out behind glove box means there is a leakage of the sealings between the fan motor and evaporator and evaporator is clogged or air is leaking between the evaporator and central heater housing.
Remove the glove box to check where the air is leaking from.
ANNGL
  • 5 POSTS
  • 1998 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 58,000 MILES
The a/c started blowing warm air when stopped at lights or going slow. Once I get up speed it starts to cool but not enough. I tried using the freeon, no help. Wouldn't take it at all. What could be the problem?
KHLOW2008
  • 41,815 POSTS
Hi anngl,
Check if the condenser fan is working.
Overfilling of freon would also cause the problem when the compressor keeps disengaging and engaging.
ANNGL
  • 5 POSTS
Yes I think this maybe the problem. That's talking money too isn't it? Thank you for replying back to me. Have a great day.
KHLOW2008
  • 41,815 POSTS
You're welcome.
If the condenser fan is not working, then it definitely means money needed to get it replaced.
ANNGL
  • 5 POSTS
Ok, I know this is going to sound dumb. But I have two fans on my car. Which one is which? If you're facing the car say under the hood. Which one is the radiator and the other air fan?One of them does click on when the ac is on. But the other has not and my temp. Gage seems to rise but not all the way to half way. When the car gets warmer the air from the ac gets warmer also. Got any other ideas, something I may can check myself or have a friend check? I will have the fan checked also. Thank you. It's actually an integra engine.
KHLOW2008
  • 41,815 POSTS
The one on drive side is the condenser fan. It should work with the AC compressor.
The other is the radiator fan and it would work only when the temperature to activate the fan switch is reached.
If the compressor and fans are working, then you would need to get the AC system high and low pressure readings to understand what could be wrong.
