2CarPros - Car Questions & Answers
1993 Honda Civic Repair Question
Topics covered: Door, Door lock, Fuse.
Asked on August 20, 2008
1993 Honda Civic Power door locks
I have read on your site where several people have had a problem with the power door locks stop working. Can you give me a direction on where to start to diagnose the problem or if you know the cause for me to start there. Is there a way to diagnoe the door lock control.
Avatar Asked by Acrock
Answer
Replied on August 22, 2008
Hi Acrock,
Before we are able to suggest what to do, we need to know your problem.
You should describe in details the symptoms etc.
Tiny Answered by KHLow2008 (expert)
39,869 answers provided
The electic door locks just stopped working I used a v/o meter to check the seitch on the driver door and it show thwe seitch is working properly. then i tried checking the door lock actuator on the driver side door there was only one position that the switch showed continuity. I don't know where to begin to check the door lock control unit that is in the driver door. It is a united technolgies unit. I got a unit out of a 92 civic but it is a mitsubishi unit and the electronics inside are completely different even though it uses the same plug for both units. I have even checked the fuse and it is fine.
Tiny Response from Acrock
1 question asked
Replied on August 23, 2008
Hi Acrock,
Is there any power supply to control unit?
Did you test the actuators?
http://www.2carpros.com/forum/automotive_pictures/192750_Civic93CentralLock01a_1.jpg
I have tested the actuatorswitch in the driver door and it will show continuity when the switch is activated, As for power to the door lock control I haven't checked that yet. It is hard for me to tell from the diagram which wire is the power wire. It seems to me that if a door actuator was bad it would short out and blow the fuse
1 question asked
Hi Acrock,
If it is shorted, it will, but if it is an open circuit, faulty actuators would not blow any fuses.
http://www.2carpros.com/forum/automotive_pictures/192750_Civic93CentralLock01b1_1.jpg
Thanks for the blow up of the control unit wiring it makes it alot easier to read. If one of the actuators is bad will it cause the rest not to work or only that door.
1 question asked
Hi Acrock,
If the actuator is shorted to ground, it will affect the others, otherwise no.
At the # 1 or # 3 of Left Front Power Door lock switch, click it to ground and see if there is any activity from the main control unit, (clicking noise of relay).
If power supply from battery input is available and ground is sufficient, the control unit is faulty.
