AC stopped working?
2003 HONDA ACCORD
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALVAFRO5353
my AC all of a sudden has stopped working. Can someone tell me what might be the problem?
Feb 2, 2011 at 6:47 PM
ALVAFRO5353
my car needed a recharge thanks for the videos
Feb 27, 2017 at 11:11 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Changes are it just needs to be recharged but to be sure lets run down these videos and guides
https://youtu.be/4UjfQKvrB6Y ac not working
and
and
https://youtu.be/uZrQCGwXfek recharge
Dec 20, 2017 at 6:54 PM
JETHRO1
  • 5 POSTS
my ac sometimes blows cold and then sometimes not. I can go to work and have cold ac, go to lunch and not cold or vice cersa....sometimes while warm it kicks in and starts blowing cold.
Wondering if this is common on Honda's or also would like to know if it sounds like an eletrical issue or a part issue like refrig low maybe from a leak??
Dec 17, 2020 at 11:12 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Jethro1,
when it is not blowing cold, you need to check if the compressor is working.
It could be a faulty control, AC clutch relay or AC clutch itself that is faulty.
JETHRO1
  • 5 POSTS
Thank you for answering. Yes, I think the relay is the problem.
The day I checked my ac and put a vacumm on system and checked refrig level it was 1.00 of a max of 1.2. No leaks that I could see but it was a little low but I did not think enough to cause the problem.
So while recharging system the compressor did not turn on so I found the relay and tapped on it, as soon as I did the compressor kicked on and blew ice out of dash after a few mins. The relay only cost me about $3.00, the dealer I work at has many car line sister stores so I was able to buy one with my employee discount from a sister store.
Everything is good to go now, I am a hero again to my family member for fixing her car again.
Thanks
Jethro
KHLOW2008
  • 41,814 POSTS
Cheers hero :)
CHAD GRIFFIN
We went to lunch and air was blowing cold. Got back in car and no ac. hot air. Fan blows, clutch not turning on compressor. Hope that it is a fuse or something easy. (Praying for that anyway) Please advise if there is an electrical fuse that runs the AC, or what else to look for. I don't think it is a freeon leak. Thank you so much for your help and time.
KHLOW2008
  • 41,814 POSTS
Hi Chad,
Thank you for the donation.
Under hood fuse box check fuse # 12 (7.5A).
Check the relay terminals for power supply.
Test the AC compressor relay, if bypassing the terminals 1 and 2 clicks the compressor, the relay is bad if power is present.
N.SAN
My a/c blows cold air when I'm driving on the freeway or when I press the gas but blows hot air when I slow down or stop.
Dec 17, 2020 at 11:13 AM (Merged)
F4I_GUY
  • 3,302 POSTS
If the fan is not cycling properly then incoming air will be warmer at idle.
Also, ensure that your a/c system is free of leaks and has enough R134a in it. (this has to be done by a licensed technician)
N.SAN
The system has been checked and is free of leaks. It seems like when i press the gas pedal, it blows cold air but when i let go of the gas, it blows hot air. The a/c will only blow cold air when the gas pedal is pressed.
KALISATJ
My air conditioning will not cool. A service man tapped on the compressor and it started. Traveled about 2 miles and it quit cooling. Sometimes when the weather is cool outside the compressor seems to work. If the temp outside gets warm, compressor never works. I am also smelling air as if it were coming from under the hood. Its not fresh and clean. Could this be a short in the switches on the dash or is my compressor going out? If the compressor is working sometimes could it be electrical?
KHLOW2008
  • 41,814 POSTS
Hi kalisatj,
Seems the compressor magnetic clutch has too much clearance and is intermittently not cutting in when power i supplied to the coil.
Adjustment can be made on the compressor clutch clearance.
If clearance is within specs, the the clutch would have to be replaced as the coil could be bad.
The air problem could be with the fresh/recirculating air mode. Check if the mde is turned to fresh air.
GFFLAKE
My AC in my car is just blowing hot air. The compressor is kicking on and there doesnt seem to be and fluid leaking from the lines holding the freon. Once in a while it will blow cold for a couple of seconds then just blow hot. Please help me out with this.
KHLOW2008
  • 41,814 POSTS
Hi gfflake,
Check the air mix door and servomotor operations.Ensure they are closing the air mix door correctly.
This guide can help us fix it
MOELOVER327
it seems to be a problem with the accord a.c because mine doe.s the same thing.and the starter went out.had to replace.
Dec 17, 2020 at 11:14 AM (Merged)
GFFLAKE
Thanks KHLow2008,
Is there a dianostics test to see which one it would be?
GFFLAKE
So I just checked when I changed the temperature from hot to cold it made a grinding noise right under the dash. Can you help me out with what needs to be changed and how to do it?
thanks
KHLOW2008
  • 41,814 POSTS
That could mean the air mix motor or its linkages.
https://images.2carpros.com/forum/automotive_pictures/192750_ACDash03AccordFig01_1.jpg
Check the air mix control motor or its linkages. When the temp control is changed, the motor should move to open or close the door.
GFFLAKE
Thanks for posting this. So it actually ends up it was the clutch not kicking on. Is there any special tools that I might need in order to complete this and is there anything that you would reccommend before I get started on it?
Thanks
KHLOW2008
  • 41,814 POSTS
If it is the compressor clutch that is not kicking in, then you have to perform test to find out what is wrong.
When the compressor cuts out, are the cooling fans staying on? If yes, then the problem is from the clutch.
If the cooling fans stops as well, then it could be a faulty magnetic clutch relay or its controlling circuit.
If you are able to perform diagnostics, get a DVOM and test lamp.
Was the freon topped up recently?
Are the cooling fans working when the compressor is engaged?
Do you have engine overheating issues?
EARLEDO
Just had new compressor put on. A/C still not working. Mechanic states has an electrical issue. Problem not in wiring or relays. Any thoughts!?
I guess I don't quite understand what the mechanic thinks it is then? If the wiring checks out and the relay is okay then the PCM is one of the only things left other than a possible sensor that is telling the PCM to not turn the compressor on.
Does the compressor clutch come on at all? You can try jumping power to the compressor and making sure the compressor comes on. Once that is okay then we can start looking at the PCM.
