2001 Honda Accord Repair Question
Asked on July 22, 2009
2001 Honda Accord leaking radiator fluid, found the leak, d
Engine Cooling problem
2001 Honda Accord 4 cyl Front Wheel Drive Automatic 116000 miles
My car runs out of water in the radiator, and starts to overheat almost weekly. Today, I think I found the leak, I took pictures from my camera phone (low quality). I could get some better pics if needed. The caption on the first pic says "Leak under there" where the arrow is pointing. On the 2nd pick, "Leak under there" , on the 3rd pic, the leak is where the big arrow is pointing, and the arrow at the top is just pointing out the location of the radiator cap.
Answer
Replied on July 27, 2009
Hi markdubi,
The radiator top tank is bad causing the leaks. This often happens when coolant level drops and instead of coolant, steam which has a higher temperature than boiling coolant is moving around in the radiator. This would cause the tank to burst over time.
You need to get a new radiator unless you are able to get a replacement top tank.
After replacement of the radiator, pressure test the syatem for possible leaks at other area in the system.
