Vibration in front end when accelerating
ELLERBE1
  • 2008 HONDA ACCORD
  • 3.2L
  • 4 CYL
  • 199,000 MILES
When I accelerate at 55 mph my car begins to vibrate. It only does it during acceleration.
Tuesday, December 31st, 2019 AT 1:38 PM
JIS001
  • 3,408 POSTS
If the vibration is only during acceleration and not when coasting then you should have your drive axles inspected. Once the inner joint starts to bind it will cause it to vibrate.
Tuesday, December 31st, 2019 AT 8:15 PM
ELLERBE1
I replaced the passenger side a few years back. Do you think the driver side is the problem?
Wednesday, January 1st, 2020 AT 4:12 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
Yes, I would check both again because there are all kinds of different qualities of CV axles. Here is a guide to help you replace the axles with diagrams below to show you how on your car:
Video
https://youtu.be/9OYxj9y3Zjc
and
https://www.2carpros.com/articles/replace-cv-axle
Friday, January 3rd, 2020 AT 2:55 PM
ELLERBE1
Thanks for all your help Ken. It was the driver side CV axle. Had it replaced no vibration during acceleration.
Saturday, January 4th, 2020 AT 4:33 AM
KEN L
  • 42,959 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Sunday, January 5th, 2020 AT 12:17 PM
BAGDER1
  • 2008 HONDA ACCORD
  • 4 CYL
  • FWD
  • 21,000 MILES
2008 Honda Accord 4 cyl. At 37MPH a low humming/vibration starts and becomes more pronounced and higher in pitch as speed increases. Some vibration felt through gas pedal also. Smooth pavement makes noise more pronounced and noticible. Local dealership claims not to hear problem, but friends, family and local tire shop employees all hear it. Noise is unrelated to RPMs. Noise is constant, never goes away. Help!
Sunday, January 5th, 2020 AT 12:18 PM (Merged)
  • 108,269 POSTS
Are the tires worn evenly? Also, is there any change in the sound when turning?
BAGDER1
The tires are worn evenly and I had them rotated by Les Schwab in an attempt to isolate the problem, this did not improve the noise. There is no change when turning, the sound remains the same. I just put my studded snow tires on yesterday (they are on their own rims) and I can still hear the noise over them. Thank you.
  • 108,269 POSTS
The only other thing I can say is have the wheel bearing checked. Also, just for the heck of it, check the backing plate behind the brake rotor. Make sure it isn't bent and touching the rotor.
NOTAHAPPYHONDAOWNER
  • 2005 HONDA ACCORD
Transmission problem
2005 Honda Accord 4 cyl Front Wheel Drive Automatic 86000k miles
i am getting a vibration in my front end, this happens when I first start to drive the car in the morning and when the car sits all day at work, the vibration lastsabout 5 to 10 minutes, I had the tires all balanced and rotated and had the brakes all checked, had the front end checked also bearings, ball joints tie rod end checked, could it be in my transmission, somebody told me I could have a problem starting there
HAVEITMADE
I have an 04 accord 4cyl with vibration in front end (steering wheel) had everything checked. Said it all looks ok. Now at my last oil change I noticed a lot of slop or play in the driveshaft on the passenger side, not the cv joints but where the shaft actually goes into the transmission.I'm about to get it checked out. Could be your problem?
EK THE HAMMER
  • 2004 HONDA ACCORD
  • 4 CYL
  • FWD
  • 75,000 MILES
The front end of the car vibrates while accelerating (when you apply pressure to the gas pedal). If you let up off the gas pedal and let the car coast. You DO NOT fell the vibration; it's weird. The vibration ONLY occurs while pushing on the gas pedal. Any thoughts?
R / Earnest King
CARADIODOC
  • 33,752 POSTS
Hi Earnest. Welcome to the forum. This is typical of a worn inner cv joint housing although 75,000 miles is kind of soon to have this problem. Under load, the rollers bind on the very tiny worn spots inside the housing and that prevents the joint from changing angles and length as it rotates. That causes the shaft to push on the rubber-mounted steering and suspension parts and transfers the forces to the steering wheel. If you want to disassemble and inspect the housings yourself, I can reply back with the procedure I used, but today you can buy a remanufactured half shaft for much less than the cost of just a new housing from the dealer. You do run the risk of getting one that also has a worn housing that got overlooked, but it isn't that common that I would worry about it. Unfortunately, I don't know of any way to verify my diagnosis other than disassembling it or replacing the entire half shaft. From past experience, I found the problem to be with the passenger side housing about nine out of ten times.
Caradiodoc
CIMPECKO
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 87,000 MILES
When I accelerate the car there is a vibration, like the front wheels are loose. The vibration ONLY occurs when I hit 60 mph. No vibration under 60 or over 60 mph and only during acceleration. The vibration stops immediately when foot is taken off the accelerator. Had tires rotated and balanced and a wheel alignment also but vibration remains. The front end of the car vibrates, can feel it through the car seats, vibration not coming through the steering wheel. Car drives really smooth otherwise, no problems steering or braking
KHLOW2008
  • 41,815 POSTS
Hi cimpecko,
Get the CV shaft inner joint checked, they should be out of balance due joints worn or lack of lubrications.
SKIP
  • 1999 HONDA ACCORD
I just installed new Michelin Hydro-Edge tires and have a slight vibration in the steering wheel. I've had the tires balanced several times and can't seen to get rid of it. If occurs between 70 and 85 MPH. It doesn't pull left or right. Moving the tires from front to back doesn't help. It started with the installation of new tires which are one size larger than factory stock, but still recommended by Michelin for this vehicle. Could it be a front end allignment issue?
LOVESCARS
  • 359 POSTS
Lugs nuts might not have been torqued properly and brake rotors could be causing problem. Your gonna have probblems with htis mechanics will tell you speed limit is a problem with diagnosing
SKIP
Thanks.I live in the Atlanta area. If you drive under 85 on any of the freeways you're going to get run over. I've been doing some research and someone mentioned it could be the frontend allignment. They called it "feathering". The tires are one size larger than standard from the factory so maybe it has thrown it off.
LOVESCARS
  • 359 POSTS
If your tires are feathering it's likley due to suspension and alignment problems tire air pressure can play a role too. I doubt too much going one or two sizes higher would cause that.
DIVER0071
  • 1999 HONDA ACCORD
  • 2.0L
  • 4 CYL
  • FWD
  • 101,000 MILES
When driving on an uneven surface at a speed between 38 to 43 mph I encounter a vibration or rattle on the front left wheel. When I accelerate or decelerate from this speed range it stops. Over the past three years I have replaced the wheel rim, tie-rod, strut and several other parts on the front-end and to no avail the problem continues. Also, I have taken this car to two Honda dealerships and five other independent mechanics and all say the front end looks fine. Please help me solve this annoying problem.
