Security alarm?
1999 HONDA ACCORD
130,000 MILES • 6 CYL • FWD • AUTOMATIC
TREADWEIGH
When trying to jump start (totally dead) the alarm sounds and lights flash as soon as I connect to a booster battery. It's the factory security system operated now by key only. Is there a way to "reset" this alarm? There has been no change in the key use but the alarm may have been activated and the car immobilized.
I can crank the engine with the alarm blasting but it won't fire because I assume it's in the "immobilized mode".
Jan 23, 2011 at 4:22 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Is the green key symbol staying on? It must go off to be able to start. If you have a spare key, try using it.
For the horn to be blaring, it is not only the immobilizer. You need to disarm the alarm as well.
this guide will help us fix it
https://www.2carpros.com/articles/how-to-reset-a-security-system
Close all doors and use the key to lock and unlock all doors before opening them.
If that does not wok, you would have to check for blown fuses resulting in no communication between the PCM, security system and key.
Jan 24, 2011 at 2:46 PM
TREADWEIGH
Thank you! The door/key/lock/unlock cycle reset the immobilizer and it started easily with a jump. I appreciate your help, can I leave a tip?
Jan 24, 2011 at 8:24 PM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Glad to know you have fixed the problem.
Pleas use 2CarPros anytime we are here to help.
Jan 25, 2011 at 1:29 AM
RICK GIOMBETTI
Thanks for the advice ! Worked well once I reset the alarm by putting the key in the door and reset! Horn stopped honking and light went off! Life saver Thanks !!!! Jumped right away!!!!
Jul 11, 2017 at 10:22 AM
  • 54,354 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jul 11, 2017 at 4:27 PM
JIM DUNHAM
It was said that "Fuse 13 powers the alarm module." Which panel? Driver's side? Passenger? Or engine compartment box?
Apr 5, 2018 at 6:18 AM
  • 54,354 POSTS
Here are all of the fuse locations and identification as well.
Check out the diagrams (Below)
Cheers, Ken
Apr 5, 2018 at 11:19 AM
KEVIN MARQUEZ
So I replaced the window regular since the window wouldn’t go up or down so when I replaced it and plug it in it did work but the car won’t turn on at all but lights do show but says like all the doors are open and the trunk and dumb idea to remove the battery and now it won’t stop beeping and keychain doesn’t work. New to this sorry lol I’m assuming it has to do with the door I fixed the regulator since I plugged it in it’s behind the driver seat one.
Sep 26, 2020 at 1:24 PM (Merged)
  • 54,354 POSTS
Is the security light flashing? It is common to reset the alarm system when the battery has been disconnected. This guide will show how to reset the system:
GOODYSONTHEGREEN
my honda 1999 accords remote is broken and the car alarm is on. How do i disarm alarm.
KHLOW2008
  • 41,814 POSTS
Close all doors and use the key to lock and unlock the door to disarm.
If it fails with one door, try thre other or trunk. If it still does not work, insert key to ignition and turn it on.
NATE4LIFE
1999 Honda Accord 4 cyl Automatic
hi my name is NATE and i own a 1999 Honda accord, at first when i press the alarm to open the doors on the car the lights would come on and off on the back and the front of the car now its not doing that no more, i dont know whats wrong with it, can u pleace help me?
Sep 26, 2020 at 1:25 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi nate4life,
If the alarm can be armed and the power locks are working, then try the procedure described in the following link and see if it helps.
NATE2NICE
my car remote does not have the trunk release button, what else can i do?
KHLOW2008
  • 41,814 POSTS
Hi nate2nice,
What problem are you facing?
Are you regiatered with 2 accounts here?
You should ask all related questions in one thread and reply in the same thread so that there wil be a history of the question that you asked and also notification would be received by the person handling your question.
KHLOW2008
  • 41,814 POSTS
Does the locking and unlocking functions work even though the lights ae not blinking?
NATE2NICE
1999 Honda Accord
hi my name is Nate, and i own a 1999 Honda accord, ever since i buy this car the security alarm would comes on when somebody gentle touch the car or when a bus pass by it. can u please tell me whats the problem ? Thank You
KHLOW2008
  • 41,814 POSTS
Hi Nate,
The vehicle is allergic to touch and vibration ;) just joking.
Most probably you have a door out of adjustment/loose or the door switch is not being activated properly.
Does the door ajar warning indicator light sometime flashes while driving?
If yes, you should check which door is out of adjustment.
With dome light switched to operate with door, sit inside vehicle and close all doors. Push at the door from inside the car and waych out which door turns the dome light on. That is the door that you should check for adjustment or switch problem, could be a missing rubber cover.
__JJ
Took my car to jiffy lube for an oil change today. When I got home, i used the remote to lock the doors and set the factory alarm. The doors locked but the blinkers did not flash and no horn beep indicating the alarm is active. So i tried my wifes remote and same thing. The remotes both lock and unlock the doors but not activate the factory alarm. This function worked by remote only moments before taking my car to jiffy lube. coincidence? any help, thanks, JJ
KHLOW2008
  • 41,814 POSTS
Hi JJ,
There is a possibility the audible signal was set to off. Try if the following helps
AUDIBLE SIGNAL
Remote keyless transmitter operation is indicated by the side marker lights, taillights and parking lights flashing once (lock) or twice (unlock). An audible indicator (alarm chirp) can also be programmed. When transmitter battery is replaced, audible indicator will be turned off.
To Switch On Alarm Chirp(s)
1. Using remote transmitter, press and hold trunk release button. Immediately press and hold the lock button.
2. The transmitter LED should light and remain on for one second. After LED goes out, release buttons.
To Switch Off Alarm Chirp(s)
2. The transmitter LED should flash twice. After LED goes out, release buttons.
remote transmitters may be coded into system.
PAMHIGHTOWER
The anti-theft alarm keeps going off when i try to open the car door to get in the car. And i dont know how to turn it off. It will go off on it on when it is finish making the alarm noise, I dont have a regular alarm either except the anti-theft,
KHLOW2008
  • 41,814 POSTS
Hi pamhightower,
Try using the key to unlock and open the passenger door and if alarm is not trigggered, it means the driver side door lock switch is faulty not allowing the alarm to be disarmed when you use the key to unlock and open the door.
MARLENE DAVIS
Someone tried to steal my car. I replace. Mobilizer and the computer and had it coded and tried to crank it just like i was instructed. It still wont crank. What could the problem be and what else could I try?
HMAC300
  • 48,601 POSTS
try resetting security system if it does not work a mechanic will have to hook up his scanner to see what is wrong, might not be programmed to your car. see link.
SCHERERLB
When I use my keyless entry remote to lock the doors, all of the doors lock except the driver's side and the back right passenger door. What is the cause of this problem?
F4I_GUY
  • 3,302 POSTS
Do the power locks work on those doors? If not, the fault is the lock actuator or the wiring going to the actuator.
KEE
I have a 99 Honda Accord with 82000 miles the problem is the alarm just keep going on and off at first we taught that maybe a cat or dog hit it then after about 5 minutes the alarm went on again and contunuie to do so every 5 minutes. all the windows, doors, hood and trunk are all closed so when i went to the dealer they told me that the Hoodswitch needed to be replace and would cost me $406 plus tax and my warranty would not cover it so i told them to just leave it i dont have to money to pay for it so what i did was remove the fuse for the Horn since the horn and the Alarm had the same fuse and now i dont have a horn. my question is what is a hoodswitch? can i just get is at some local auto shop and have my mechanic put it i dont want to pay dealer price? if so where can i find this hoodswitch?
Sep 26, 2020 at 1:26 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
You can buy new system and have it installed for less
if its the hood switch have u r local mechanic check it and replace it or disconnected
KHLOW2008
  • 41,814 POSTS
Hi Kee,
I guess the switch would not cause more than 10 bucks.
Btw removing the fuse is not a good way of stopping the problem. The alarm would still be triggered without the horns sounding. Disconnecting the hood switch wire would be a better option.
I would check for proper adjustment rather than a faulty switch. A faulty switch should not trigger but a badly adjusted switch would.
KEE
ok is there a way i can obtain a diagram as to where the switch would be located at? so i can fix the problem as soon as possible like you said taking the fuse out is not the solution. Wow thanks for mentioning that is would only cost me $10, i cant understand why the dealer would so much over price me for such a thing.
KHLOW2008
  • 41,814 POSTS
Hi Kee,
Sorry I have not been able to locate any diagrams to show you.
Open the front hood and look for a plunger type switch along the edges of the engine compartment.
