2CarPros - Car Questions & Answers
1997 Honda Accord Repair Question
Topics covered: Engine, Sensor, Radiator.
Asked on August 10, 2010
1997 Honda Accord Where is the coolant temperature sensor 1
Engine Performance problem
1997 Honda Accord 4 cyl Two Wheel Drive Automatic 190000 miles
My car has the sympstoms of a bad coolant sensor and I would like to replace it myself but can't figure out where exactly it is located. A photo will help. Thanks!
Avatar Asked by japslico
Answer
Replied on August 10, 2010
http://www.2carpros.com/forum/automotive_pictures/261618_Noname_2559.jpg
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
Replied on August 11, 2010
Thank you for the illustration, it helps me figure out which is which.
Tiny Response from japslico
4 questions asked
Would you know the product code of the Engine Coolant Temperature Sensor for the 1997 Honda Accord SE at Advanceautoparts? I bought the ECT sensor with a product code WT5009 and it is not the same fit. They asked me if this is for the computer system or the cooling system.
4 questions asked
O.E.M #37870-PK2-005
Replied on August 12, 2010
Can't find that code. The ECT sensor at Advance Auto Parts that I bought has a code of WT5009 which does not fit and the other one that I searched online was WT680.
4 questions asked
those are the different companies part numbers they use for their systems, the actual OEM Honda part number is what i listed last post.
Replied on August 15, 2010
Please see encircled item on the photo. Is that what I need to replace when my radiator fan is still on even after the engine is off and I noticed a decrease in engine power as well as increase in fuel consumption? Thank you for the help and what tool will I need to replace it? Thanks again.
http://www.2carpros.com/forum/automotive_pictures/560077_FSCN0411_1.jpg
http://www.2carpros.com/forum/automotive_pictures/560077_FSCN0412_1.jpg
4 questions asked
no, faulty radiator fan relay would be the cause of that issue..
Do you have a photo where it is? Is it the same as the radiator fan switch?
4 questions asked
it is a relay, some may call it a switch though. it is located in pic below..
http://www.2carpros.com/forum/automotive_pictures/261618_Graphic_651.jpg
