I have the wagon. I replaced transmission about seven months ago. D4 light has been blinking since day one and previous owner said had the same issue. It has worked fine until speedometer started jumping and stopped moving and D4 stays solid. Now will not shift. Sometimes jumps up and down and starts blinking but, now stays lit up and speedometer not working and no shift. I had to repair a few wires on shift solenoid but it has been good for the past seven months. I am stumped. I have even replaced ECU, it worked for about two weeks with D4 blinking. Now I can only use low 1 and 2. What could be the issue? I have narrowed down to wiring, because it will still shift good when I would did kick on.
May 23, 2018 at 11:03 AM
