The car lighter/12v power outlet is not working. How do I replace it? Where can i get a replacement? Could you please let me know the procedure.
Dec 23, 2010 at 11:09 PM
HONDA TECH 1818
CAR REPAIR CONTRIBUTOR
Here are diagrams to help you change the power outlet. You should also check fuse No. 9 (15 A) or No. 32 (7.5 A) fuse in the under-dash fuse/relay box. Here is a guide to help with diagrams below.
Images (Click to enlarge)
Dec 24, 2010 at 7:03 AM
MWHEELER89668
MEMBER
1 POST
Can you tell me where i can find the fuse for the power outlet just under the radio
By the shift lever.
Jan 9, 2019 at 11:25 AM
(Merged)
HONDA TECH 1818
The fuse is located in driver's side fuse box at the kick panel, it is fuse #9 15amp fuse
(Merged)
BLUEBERRY409
MEMBER
1 POST
Electrical problem
2003 Honda Accord
The front accessory power outlet in my 2003 Honda Accord does not work. I first checked the fuse for the accessory outlet and replaced the fuse. The outlet still does not work (and yes I have the car in ON). Also, the outlet in the glove compartment does not work. My charger working in my other car...so it is not the charger. Your help would be much appreciated.
(Merged)
Hi blueberry409,
There is one fuse you need to check #32 7.5 amp int he fuse panel here is a guide to help you see how to check the fuse.
Here is the power outlet wiring so you can see how it is powered and the fuse box diagrams.
Check out the diagrams (Below)
Cheers, Ken
(Merged)
RON1111
MEMBER
The front accessory power outlet in my 2003 Honda Accord V6 does not work. I check my owner manual and couldn't find the power outlet fuse. Other power outles fuse in the CD compartment works but the outside near gear shift don't work at all.
Please help
Thanks
Ron
(Merged)
F4I_GUY
Check all your fuses with a testlight or fuse tester. This will ensure that you do not have a blown fuse for any circuit.
If the fuse isn't blown (which usually that is the case) then you will have to check for power and ground to the outlet.
(Merged)
RPRUITT
MEMBER
1 POST
I recently noticed that my dc power outlet for my car charger is no longer working. I plugged the charger into my husband's truck and it worked. My husband checked all of the fuses on the inside of the car and under the hood. He replaced the 7.5 and the 40 fuse and it still did not work. He bought me a navigation system for Christmas and I want the power outlet to work. Please help!!
(Merged)
KHLOW2008
Hi rpruitt,
You need to check for power supply to the power outlet. If power is available, the socket is faulty.
You need to remove the socket wire harness to check.
(Merged)
PAOSIN
MEMBER
1 POST
Please I have 2005 Honda accord and the two power outlets doesnt work, i am not sure even sure of the fuse that goes there because any was not labelled for the power outlet.
Please kindly help me on what to do .
(Merged)
KHLOW2008
Hi PAOSIN,
Check the following fuses
1. No 9 (20A) fuse at passenger side fusebox.
2. No 8 (7.5A) at driver side fuse box.
3. No 54 (40A) under bonnet.
Jan 9, 2019 at 11:26 AM
(Merged)
78NOVA
MEMBER
Hey Everyone. My power outlet (cigarette lighter) doesn't work in my pals ninety three accord. I thought it might be a fuse. I contacted my local Honda dealer and he said the fuse for the lighter was the same as the power antenna motor under the dash. I checked it and it was not blown. I was just curious if anyone knew what the problem might be. I'm thinking it might be the heating element but I'm not sure. Thanks for your time. Hopefully someone can help.
(Merged)
LEGITIMATE007
yes it could be, check the fuse box for cigarette lighter and see if it is blown, then verify that there is power going to the cigarette lighter housing, if so , then its the lighter itself that is bad(element) and you'll just have to replace it
(Merged)
MISSNAY1121
MEMBER
1 POST
How can the power outlet in my car be fixed?? When i plug my charger into it doesnt work. I tried replacing the fuse and still nothing happens. What can I do?
(Merged)
KHLOW2008
Hi missnay1121,
You need to check if the charger plug is compatible or good. some plugs might not be getting the proper contact to work.
Test for power supply to centre pin of power outlet, if no power, either the socket or fuse is bad. If socket, you need to replace it.
(Merged)
