ECM Relay location - PGM fi-1and PGM fi -2?
2007 HONDA ACCORD
130,000 MILES • 4 CYL • RWD • AUTOMATIC
MLANDRETH87
I need to know where the ECM Wiring Relay is located so that I can replace it. I have the part
Jun 15, 2015 at 8:10 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
There is two ECM relays called PGM fi-1and PGM fi -2. Here is a wiring diagram and the relay box location which is under the dash by the kick panel on the drivers side.
Here is a guide on how to test the relay
Cheers, Ken
Mar 28, 2017 at 8:15 PM
JONESTIFFANY2
  • 8 POSTS
i need to know where t can find the main relay?
Jan 18, 2021 at 8:47 AM (Merged)
KHLOW2008
  • 41,814 POSTS
It is labelled as PGM-FI ECU main relay if that is what you are looking for.
JONESTIFFANY2
  • 8 POSTS
Thanks
KHLOW2008
  • 41,814 POSTS
You're welcome.
Have a nice day.
DOC GOINS
where is the main relay located is it easy to replace
Jan 18, 2021 at 9:19 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
behind left side of dash
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_740.jpg
Here you go and have a nice day
https://images.2carpros.com/forum/automotive_pictures/12900_main_relay_PGMFI_1.jpg
FINALLY26
After having the Honda problem where the car won't start and the "D" blinks on the transmission pattern on the dash, I found a great article explaining how the Main Relay is often the cause of this as the resistance changes due to poor/cold solder joints on the baord from the factory, allowing so much juice through it places the car into "limp mode".
I replaced the Relay and the car started great. I drove 1 mile and came to a stop sign. As soon as the car came to a stop (in drive) it started to run very rough. It won't stall but sounds like it is missing. I nursed it back home.
Any idea if something further down could have fried now due to "stronger relay", or any ideas what to check next?
no engine lights or codes showing.
Thanks
KHLOW2008
  • 41,814 POSTS
Hi finally26,
Thank you for the donation.
There is no such thing as a stronger relay. The work of the relay is to control power supply to the ECU and fuel pump.
We need to understand what is causing the problem and it could be something different and nott related to this.
Did you check the spark plugs, wires and distributor?
Is the Check Engine Light indicating?
Is the D4 light blinking?
MAXBAUSKE
Computer problem
1992 Honda Accord 6 cyl Front Wheel Drive Automatic 161k miles
Hi there!
I've had a problem with my 1992 Honda Accord EX lately, it's been dying. The car has two symptoms, but I'm wondering if they could be related to the same issue.
The FIRST PROBLEM I'm having is one I've read about quite a bit on the internet. It sounds like it's very common to have an Accord with starting issues. Here is an exact description of my problem, as written by another Accord owner:
"My '92 Accord EX sometimes won't start, either. It seems to be more common on a hot day and/or after a short period of being turned off, before being restarted, but that's not 100%. It can go for days or weeks without this problem, or may do it a couple times in a day. Note that it cranks fine, but never fires. However, the green square around the D4 indicator always starts blinking when it won't start like this -- which indicates a transmission problem. I don't think there was any pattern to it at those times -- just on and off about every second."
My SECOND PROBLEM is a bit more severe. When I'm driving the car, after about ten or fifteen minutes it shuts down. It happens at stoplights and while driving. It is not speed dependent either. The first thing I notice is the gas pedal loses power, then the steering locks up, and finally the brakes get REALLY hard to use. I then find myself praying it makes it to the side of the road. I took it into a local repair shop, where I was told it was the main relay's fault, that it was shorting out after it warmed up. The mechanic replaced it with a used main relay, but that night it died again. So I took it to the mechanic a third time and he replaced the used one with a new one for no charge. It sounds like it's starting stronger, and seems smoother to drive, but I'm afraid to drive it too far. Since visiting the mechanic yesterday I have driven it maybe four or five miles. It seems the first two times I brought it home from the mechanic it only lasted 8 or 10 miles before dying.
My friend was videotaping briefly when my car died, and here is a link to the video. At the end you can hear the car trying to start up. I don't know if that is any help. Ha ha.
http://www.youtube.com/watch?v=XfACNZgxqtw
What do you think I should do?
KHLOW2008
  • 41,814 POSTS
Hi maxbauske,
Did the policemen frightened your friend that he dropped the camera? ;)
Seems to be two faults and one of it has been addressed with the replacement of the PGM-FI main relay. Guess you do not see the D4 light blinking while starting.
The two most common causes for starting difficulties due to electriacl faults are the PGM-Fi main relay and ignition switch.
I take it to mean the dashlights were not showing as you did not notice the engine stalling except for the response from the throttle etc.
When engine stalled without the dash indicator lights showing, the power supply has been interrupted and the ignition switch is one of the most common cause.
The next time it is difficult to start, turn ignition OFF. slowly turn to ON. Note if the dashlights are showing and do they flicker.
Slowly turn to START and note the indicators, if the flicker or goes out, the switch is bad. Sometimes when the ignition switch fails, the engine would start but once the key is released, it stalls.
TJSLRS
1990 Honda Accord Fuel delivery issue.
I am currently troubleshooting a fuel delivery issue on a 1990 Honda Accord. I have already tested the Main Relay both from the connector and the relay itself and it tested OK. Proceeded to empty and drop the fuel tank since my 90 accord only has 1 access panel for the fuel gauge sending unit which wasn't much help for this issue.
At this point I have removed the tank and now that I have open access to the fuel pump connector I put a meter to that and flipped the key and low and behold I have no power at the connector. My assumption now is that I must have a break in the wire unless I am missing something.
My thought now is to trace the wires from the fuel pump connector back towards the front of the car and see if I can find a break or test and see power being sent out towards the pump.
Any thoughts for my process or advice on where else to start??
Respectfully,
Tj
Jan 18, 2021 at 9:20 AM (Merged)
Check the yellow wire if its open from the main relay to the fuel pump-
WRENCHTECH
  • 20,761 POSTS
Let me add this...
Don't be expecting power there for more than 2 seconds after the key is turned on if at all. It should resume when you start cranking.
TJSLRS
Thanks for the responses. Just thought I would update this since I have recovered and resolve the issues.
First let me say that I actually had 2 issues which is what was complicating things a little bit.
1) Intermittent issue with the MAIN RELAY (which was located under the dash cluster and hidden by the cruise control box.
2) Fuel pump was faulty as well.
Originally when testing things out the RELAY tested ok but after putting it back up into its space found that it was no longer working which threw me.
pulled the MAIN RELAY back out again and bypassed the relay to test current to the fuel pump connector which now gave me a constant 12.xx volts. This answered my original question.
Next bench tested the pump with 12volt power supply and pump didn't move. This confirmed the pump was gone. Also ran a continuity test on the pump which also confirmed the pump was done.
NEXT STEPS:
Found a nice article on repairing MAIN RELAYS. Apparently there is a problem with the soldering method used on the original RELAYS causing intermittent failures over time. Benched the RELAY and de-soldered / re-soldered all connections. Tested the RELAY again and it tested OK.
Re-installed the RELAY and retested @ the fuel pump connector and it still tests OK. I purchased a NEW RELAY and will be holding on to it just to be sure the intermittent issues caused by the RELAY are gone.
Replaced the Fuel pump and re-installed the pump and tank in the car.
Voilla I am on the road again.
Thanks again for the replies and Hope this post helps anyone else who might run across a fuel delivery issue.
Tj
DELY0575
Where is it located???
There you go its located below PGM_FI main relay Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://images.2carpros.com/forum/automotive_pictures/12900_relay_11.jpg
ESTORM
  • 6 POSTS
Hi does a 1988 Honda Accord LX have a main relay and if so where is it located?
Thanks!
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle's EFI Main Relay is located under left side of dash, above fuse/relay block.
Thanks for using 2CarPros.com!
ESTORM
  • 6 POSTS
Thanks! I still cannot find it! Does carb. model have main relay or just FI model...?
Thank you
BLUELIGHTNIN6
  • 16,542 POSTS
My sources only list an EFI main relay. Are you having trouble getting power to fuel pump?
ESTORM
  • 6 POSTS
Thanks...Is EFI Main Relay standard on 1988 Accord LX? Having problems starting car. Turns over, no start. Replaced coil, plugs, wires, cap, rotor. Checked all fuses and most relays. Dist. turns, camshaft turns, timing belt good. It seems there is no spark. I have fuel at the front filter, right before the carb. No clicks from under dash, oil light stays on. Was thinking relay. Thank you so very much for your help, this has been a real mystery!
Please respond when you have a chance!
Thanks in advance-
BLUELIGHTNIN6
  • 16,542 POSTS
Have you checked crankshaft and cam position sensors?
