Severe Engine Oil Leak?
DJ00140
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 167,668 MILES
Ok so I have 94' Honda accord DX 2.2L vtec w/ an f22b automatic, I got it from a good friend who got it with a fresh head gasket. It's leaking about a 1/2 to 1 qt every other day appx. I knows its not the oil pressure switch, just got that done, just got the oil pan gasket done, not the valve cover.
It's leaking from the passenger side rear corner of the engine, the first mechanic did all the other work on it (except the hg) and sprayed it all down cause the entire engine was covered in oil and said it had to be the head gasket. He thinks the mechanic who did the HG before didn't do a good job because he didn't change out the water pump or timing belt, which got done after. The upper end looks new because its all shiny but IDK (maybe new head?).
The car doesn't leak any anti-freeze and doesn't overheat or smoke. It just started smoking out of the exhaust but that was just cause it was cold thismorning?
Anyways the second mechanic was a little better and had a camera to look around and said it might be the HG but wasn't sure because it was covered by the transfer case but it was for sure the rear passenger side of the engine and was leaking down some tube. It leaks the majority when its running so I can only think it could be a cracked block or the HG, but that was just done. What else is in that area that it could be please help! Thanks in advanced.
Following parts were just done:
-oil filter (yes it is tight)
- brakes and tires
-oil pan gasket (which is missing a bolt but isnt leaking)
-water pump timing belt and radiator
-distributor wires and plugs
The whole bottom half of the engine is covered front to back and pretty much the whole front half bottom of the car
I know where its coming from but its covered by the transfer case, What is in that area that can leak. Im trying to diagnose possible problems before I take it apart.
Also Is there any way to rule out a head gasket or cracked block due to no oil in the anti-freeze, not over-heating, not running rough at all? Or are all these still possible with these problems?
Thursday, March 18th, 2010 AT 9:43 PM
CARADIODOC
  • 33,752 POSTS
This sounds like the rear main seal is leaking which you will need to remove the transmission to replace.
Here is a guide
https://www.2carpros.com/articles/crankshaft-main-seal-replacement-rear
This guide can help as well
https://www.2carpros.com/articles/engine-is-leaking-oil
Thursday, March 18th, 2010 AT 10:39 PM
DJ00140
Thanks that's the response I was looking for, I will let you know for sure when I get it fixed, but If its dumping 1/2 to 1 qt every other day wouldn't there be more symptoms if its the head gasket or not necessarily? I will let you guys know within a week! None of these is more expensive than a head gasket right??? quick estimates would help so i dont get ripped off. if its not the head gasket im going in in a few days:
-Where Gear Case meets Bell Housing
-vtec solenoid valve
-gasket for cam sensor
-rear cam seal
-cam sensor o-ring
-oil galley plugs
https://www.2carpros.com/forum/automotive_pictures/503072_100323_180616_1.jpg
Ok today i went under the car and it was dripping in between the tranny and engine... rear main seal??? I took a pic
Tuesday, March 23rd, 2010 AT 6:29 PM
CARADIODOC
  • 33,752 POSTS
What you have to look for is the highest point you find oil. The rear main seal and some oil galley plugs require removal of the transmission to get to them. A few engines, most Chryslers for example, have a two-piece rear seal that only requires removal of the oil pan to replace it. That takes about two hours. Removing and reinstalling the transmission is usually at least a six hour job.
The other four things you mentioned are in the open where leaking oil would be easy to see.
Caradiodoc
Tuesday, March 23rd, 2010 AT 6:52 PM
DJ00140
UPDATE!
Ok so this mechanic I found on craigslist says he can find out whats going on and give me an estimate before he does any work. $100 to remove the intake manifold and find the leak. So He calls me and says its $400 and I can come look at it and he'll show me what he did, Im like wtf I thought you were gonna call me first and tell me what needed to be replaced. But anyways I get there hepoints to the vtec solenoid and says he had to take off the intake to get to it.
I'm like you dont have to take the intake off to that im not paying $400, you didnt even ask my permission to do the work (im guessing since it was such an easy fix and he already put that much work into it he just finished it up) But then he's like well your not getting your car back until you pay me the $400, so im like yea ok and call the police, they get there make me pay the $100 which I agreed I owed and took the car, he tried to get me to sign something ad im like no way, and he just put paid in full for $100 so I signed it so he couldnt take me to court which was his only option of gettting paid!
So long story short I got it fixed for $100 and a bunch of BS but how much would a honda dealer charge me for this, he just replaced the gasket seal that has 3 circles with the strainer looking part on one part that attaches the solenoid to the engine.
Tuesday, March 30th, 2010 AT 7:58 PM
CARADIODOC
  • 33,752 POSTS
Hope this takes care of it. Sorry for all the grief. Up here in Wisconsin, we sign a repair order with the maximum amount listed. You can't be charged more than that amount without your permission.
Caradiodoc
Tuesday, March 30th, 2010 AT 9:48 PM
KAYCEE20
  • 1994 HONDA ACCORD
  • 4 CYL
  • 200,000 MILES
About how much would it cost to fix an oil leak?
Tuesday, August 25th, 2020 AT 11:49 AM (Merged)
F4I_GUY
  • 3,302 POSTS
It depends where the oil leak is coming from. For example, if it's a crank seal, it could cost $300. If it's an oil filter, it could cost you $10.
GETTEROBO
  • 7 POSTS
Where is the leak coming from. If it's the oil pan gasket. Get more information because this may be a common problem.
KALYAN99
  • HONDA ACCORD
I have a 1994 honda accord auto transmission recentley it has got an oil leak I can see the oil leak near the bottom end of radiator like I can can see the oil leak from the housepipe going out from radiator by seeing the colour of ythe oil I can say it is transmission oil could u explain me about the transmission cooling system and weather the transmission oil passes through the radiator for cooling.
Tuesday, August 25th, 2020 AT 11:50 AM (Merged)
BRUCE HUNT
  • 3,753 POSTS
That is affirmative. The oil from the tranny is cooled in the radiator. I would check where the leak is coming from and then if it is from the core or the radiator itself, I would replace it. Don't mess with anything else. They can run around 80 new. You could also check to see if one of the connections has loosened up and retighten it.
AFIALA
  • HONDA ACCORD
My 94 honda accord is leaking oil from the top of the pan, right where the dip stick sleeve goes into the pan.I thought at first it was the o-ring in the sleeve, so I replaced it and it still leaks just right in the area in between the where the sleeve goes into the oil pan. So what can be the problem and how can it be repaired?
FISHERMAN
  • 937 POSTS
Hello !
Clean the area and see exactly where the oil its coming from.
Could be an small "crack" on the dip stick tube housing.
If that its the case some epoxy on a clean oil free area should solve the problem!
Good luck and let us know!
IRT
  • HONDA ACCORD
Honda accord 1994l; milage: 234 000km, sedan Vti. I just had the engine replaced about a year ago because of the head gasket but now it seems like theres a leak comming from under the car I am not sure where and how to solve it? Does it mean I need another new engine? Can an "engine seal" fluid that you can buy help?
FISHERMAN
  • 937 POSTS
Hello!
Oil Leak?
Water Leak?
Transmission fluid leak?
How bad its the leak?
(I`m not recommend any leak sealer)
let us know!
DAPYDO
  • 1993 HONDA ACCORD
  • 4 CYL
  • 230,000 MILES
I have replaced: all upper seals, installed new timing belt and balencer belt. Still there is an oil leak. Must have missed something. Suggestions? Dan
Tuesday, August 25th, 2020 AT 11:51 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Dan,
Where is the leak coming from?
If it is at timing belt side, possible areas are:
1. Crankshaft oil seal.
2. Balancer oil seals.
3. Rear balancer housing O ring.
4. Valve cover gasket. Check for proper installation.
DAPYDO
Thanks for the ideas, will check it. Dan
NATESF
  • 1993 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 215,000 MILES
My car randomly decided to puke out all of the oil I checked th plug and all the seals and I tried to find the leak by pouring oil into the car with no luck any suggestions as to how to get repaired without getting ripped off
KHLOW2008
  • 41,814 POSTS
Hi natesf,
There are many possible areas for oil leakages and some of them requires replacement of seals that require a lot of time.
You can get an assesment from various sources to get an idea of what needs to be done and the estimated cost.
MATTHEW KIEHL
  • 1993 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 13,000 MILES
When I start the car it dumps oil from somewhere by the belts lower shafts maybe. Do you know what that might be and a rough estiment on getting that fixed? Thanks matt
