Stalling problem
PETERROSS
  • 2007 HOLDEN BARINA
  • 1.6L
  • 4 CYL
  • MANUAL
  • 62,000 MILES
Fitted new timing belt, the engine will not learn re idle, followed directions from gm repair manuel. Scaned for fault p300 multiple miss fire. Have tried several times still no good
Peter
Tuesday, March 4th, 2014 AT 5:44 PM
KNOWLEDGE IS POWER
  • 1,136 POSTS
It sounds like you've got a tooth off on the timing belt id check that first
This guide can help
https://www.2carpros.com/articles/engine-stalls
Wednesday, March 5th, 2014 AT 6:46 PM
PETERROSS
Thank you for your help, the timing belt was 1 tooth out. Have repaired the fault and the Barina is running A1
Thanks again Peter
Peterross
Monday, April 7th, 2014 AT 9:43 AM
CIARANSOFT
  • 1995 HOLDEN BARINA
  • 4 CYL
  • 150,770 MILES
Hi.
My Holden Barina keeps stalling randomly. Ill be driving along and all of a sudden, the check engine light cuts in and the engine dies after 5 seconds. You sometimes have to wait until you can restart it for a minute or too. Ive had it serviced several times and holden cant find anything wrong with it. It sounds like it isn't chainging gears when in drive, but ive tried changing gears manually and it still stalls. Before I got it serviced, it used to start straight away and only stall when idolling at intersections.
Just before stalling, it makes a loud revving noise and sometimes kicks back in but othertimes I have to wait to restart it. Mostly it cuts out without warning. Ive replaced fuel injectors, temperature sensors, everything but still cant find the problem.
Any help you can give is appreciated greatly.
Wednesday, May 20th, 2020 AT 11:27 AM (Merged)
  • 31,938 POSTS
Hi there.
A ECU scan will pick up any set fault code, the check light is an indication that a code has been set, I would also have the idle control system & vacuum leaks checked as well
mark (mhpautos)
NANZAF
  • 1992 HOLDEN BARINA
  • 159,000 MILES
My Holden barina keeps stalling and then cuts out when battery light appears on dashboard. My mechanic changed, fuel pump, fuel filter, carburetor. Had a new battery fitted by RAC in Perth, Australia not long before problem started. Sent to auto electrician and they suggested change alternator, but it may not fix the problem. My mechanic has tested alternator and says it does charge the battery, so it can't be that. My mechanic can't seem to find the problem or reasons why this keeps happening on occasion. It's a safety risk to drive since I don't know when it may stall on the road or in traffic.
  • 108,200 POSTS
What light comes on when it dies? Did anyone check the fuseable link between the alt and the battery? Is the battery dead when it dies?
NANZAF
Battery light comes on when it cuts out. Car starts again afterward every time. Not sure if mechanic checked fuseable link. He insists battery n alt is fine since he tested it. Strangely it never happens when he had the car to fix it. It cut out a few times in winter whilst we drove it on the highway or in traffic. I drove it this morning for 30 km and it was fine. So not sure what it could be. Hubby insists I can't drive it to work (1hr) away, unless its sorted.
AMIEEH
NANZAF - was this issue fixed? I have had it twice now with a holden barina spark 2013 model
  • 31,938 POSTS
Is the battery light coming on before the stall?
FMONZON
  • 1988 HOLDEN BARINA
  • 4 CYL
  • FWD
  • 190,000 MILES
Engine stalled when I shift the gear to drive. Even I increase the revs in the carburator.
RACEFAN966
  • 5,029 POSTS
OK I have no info on your car so I need to ask some questions so I can try to help you. Is you car carburated or injected? How does it stall does just cut off like you turned off the key or does it act like it running out of gas.
FMONZON
My engine is fine when in neutral but when I shift it will stalled. I can drive it when I step on gas pedal and control it with brake is on. I got G13A engine
RACEFAN966
  • 5,029 POSTS
OK good but a G13A tells me nothing as I have no data base on this car it wasn't made for the states. I know it is an Izusu power plant so I intend to use that to try to help with you problem. I do need to know if it is injection or carburation? Get back to me with that so I can try to help.
FMONZON
My car is carburettor, I cannot adjust to idle. I think my RPM high that is why, I have a problem when shiffting in to gear. For example from park when moving to reverse or sometimes to drive, the engine stop. I find it revs must be high but I could not adjust it to take it down. I don't hame RPM or tachometer to know how high it run.
RACEFAN966
  • 5,029 POSTS
Ok so I would check the idle control soloniod and mixture control soloniod. Could you include a pic or two of your carburator so I can see what all is on it for controls? Thanks.
