ignition switch replacement instructions please
2007 GMC SIERRA
150,000 MILES
DERRICK8974
Security light stays on and engine will start then shut down after couple of seconds. Tried resetting by turning ignition on for ten minutes then off three times to no avail. Is this ignition switch?
Jan 3, 2013 at 6:32 AM
SEVAG P
  • CAR REPAIR CONTRIBUTOR
  • 405 POSTS
hello,
please read the fault codes then send to us to narrow down our problem.
have you tried to start the car with another spare key? is the vehicle locked and unlock by using remote control?. try to disconnect the battery wait for 20 minutes, then reinstall and try to start the engine.
use our link below try to reset the system again.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Check our link below how to read fault codes.
Try to perform the instruction then we continue our diagnostic steps if the problem from ignition switch or not.
check the diagrams below how to replace ignition switch in a case of problem defect.
let us know if you need more help.
thank you.
Feb 8, 2021 at 6:59 AM
MBOUDREAUX225
Someone broke into my truck and now I can’t even turn my ignition.
Feb 8, 2021 at 12:22 PM (Merged)
Good morning,
I attached the procedure for replacing the key. Since it will not turn to the on position for removal, you will need to drill out the pin for the release of the cylinder.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If you call a locksmith, they will come to you and repair it on site.
IGNITION LOCK CYLINDER REPLACEMENT
Removal Procedure
1. Disconnect the negative battery cable.
Caution: When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
2. Disable the SIR system. See: Air Bag(s) Arming and Disarming > Procedures
3. Lower the hush and knee bolster.
4. Remove the steering column trim covers.
5. With the key installed, turn the key to the RUN position.
6. Install an allen wrench into the hole on top of the lock cylinder housing. Push down on the allen wrench to release the tab on the lock cylinder inside the lock cylinder housing.
7. Slide the lock cylinder out of the lock cylinder housing.
  • 110,190 POSTS
I believe you will need to remove the ignition lock case. Take a look through these directions and see if they will be helpful.
Note: The attached pic correlates with the directions. Note this is for the removal of the entire lock cylinder case unit. If you want only the lock, let me know.
____________________________________
2003 GMC Truck C 1500 Truck 2WD V8-4.8L VIN V
Ignition Lock Cylinder Case
Vehicle Steering and Suspension Steering Steering Column Service and Repair Removal and Replacement Ignition Lock Cylinder Case
IGNITION LOCK CYLINDER CASE
Removal Procedure
1. Disable the SIR system.
2. Remove the ignition switch. See: Steering Column > Removal and Replacement > Ignition Switch
3. Remove the turn signal cancel cam. See: Steering Column > Removal and Replacement > Tilt Head Housing
4. Remove the park lock cable from the lock cylinder housing.
see pic 1
5. Remove 3 TORX screws.
6. Remove the lock cylinder housing from the steering column.
Installation Procedure
Notice: Refer to Fastener Notice. See: Engine, Cooling and Exhaust > Vehicle Damage Warnings > Fastener Notice
see pic 2
1. Install 3 TORX screws into the lock cylinder housing. Tighten the TORX screws to 7 Nm (62 in. lbs.)
2. Install the turn signal cancel cam. See: Steering Column > Removal and Replacement > Tilt-Head Housing
3. Install the park lock cable into the lock cylinder housing.
4. Install the ignition switch. See: Steering Column > Removal and Replacement > Ignition Switch
5. Enable the SIR system.
Let me know if this helps.
BWATERS
Over the past couple of weeks, my digital clock has reset to 12:00 when I start my truck as if the power was interrupted. It has become more and more frequent. I also notice my headlights would dim slightly on occasion. This morning as I switch my transmission from reverse to drive, all of the sudden all my dash indicators lit up as when you first start the car. Then when I stopped and turned my ignition switch to the first position after run to turn off my engine, the car went completely dead, no power at all. I played around with the switch, the shifter and then I think it was when I hit my brake pedal, all of the sudden the power returned!! Please help with any suggestions on whether its possibly the ignition swithch, a relay, or whatever. Thanks.
Feb 8, 2021 at 12:23 PM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
first check the connection at the p[ositive side of battery, if it has 2 positive cables then there is a lead spacer between them thats probably worn out, if thatts ok then replace ignition switch
RIDINGHIGH2002
i went to start my truck and the key wont even turn at all in the ignition and the steering wheel i noticed isnt locked like it usually does and i cant shift into any gears. the key slided in and out but wont turn at all. what is broke on it what do i need to replace and how much will it cost about. thanks. i dont know if anyone is local but im in la mirada buena park area of so california and need to get this fixed immediately. thanks brian.
DENNYP
  • 1,824 POSTS
sounds like the tumblers in the lock cylinder are stuck.Try squirting a small bit of WD40 into the cylinder,then jiggle the key while attempting to turn it.If this doesn't work,you will need to replace the lock cylinder.The cost will depend greatly on how difficult it is to remove the damaged cylinder.
JANICET
i need to change the ignition cylinder and need direction on how to accomplish that. I have purchased the new cylinder from a dealership and had it keyed to my VIN. I have the steering column cover off...................now what?
DEONCOLLINS69
[quote:8a4276c07e="Janicet"]Interior problem
2001 GMC Sierra 6 cyl Two Wheel Drive Automatic 125000 miles
i need to change the ignition cylinder and need direction on how to accomplish that. I have purchased the new cylinder from a dealership and had it keyed to my VIN. I have the steering column cover off...................now what?[/quote:8a4276c07e]
You will need a small punch or even a paper clip to release the cylinder. Unhook the battery before you start this process.
With the bottom and top cover off look at the area around the cylinder. You will see a small hole about 1/32 to 1/16 in size on the top side of the assembly. Note there is another hole about 1/4 in size just below it. Turn the key forward until you are in the start position. Put the paperclip in the hole and push in. At the same time pull out on the cylinder. It should release easily. Now just slide the new cylinder in place and turn it.
CHRIS MCKOWN
Key will not turn to start vehicle without maximum effort.What will have to be replaced? Ignition will not turn easily.
BLUELIGHTNIN6
  • 16,542 POSTS
Try lubricating lock cylinder with WD40. You can find more information about this common issue on our "First Things to Check" page, linked on the left the page.
GO88GODJ
It is stuck in the start mode. We removed the starter and ignition fuses and removed the battery cuz it won't turn off. what can i do
My daughter started the truck and the ignition is stuck in the start mode. The key will not budge.
The starter turning and so w remove the fuses for the ignition and the starter and disconnected the battery so it would not catch fire. How do I get the key out and keep his from happening again?
Feb 8, 2021 at 12:24 PM (Merged)
  • 31,937 POSTS
Probably a collapsed ignition key barrel, if the key will not turn this is normally the cause.
MAYNARDMAN
  • 9 POSTS
i had a 2000 silverado that the key stuck on.but mine stuck in the accessory position.i got the key to turn by removing the passlock cable that is attatched to the ignition cylinder housing.you have to remove the column trim and the cable should enter from the bottom of the housing.once you get the cylinder back to the off position,leave the passlock cable out,turn the key forward too the on position,and depress the locking pin on top of the housing as you turn the key back to the off position.the cylinder should come out at this point.
JOHNNYMACDIVER
I am looking for installation instructions to remove and replace the keyed ignition cylinder. 5.3L SLE Extended
RACEFAN966
  • 5,029 POSTS
Ok first disconnect neg battery cable. Now remove the upper and lower steering column trim covers. Set tilt in mid position. Remove steering wheel make sure to remove the air bag fuse first. Roll back the shift lever seal, remove tilt wheel lever. Hold ignition in start position and use a bent awl or small allen wrench and press lock cylinder retaining pin (see pick), release lock cylinder to run position and remove lock cylinder. Put in new lock cylinder and put it all back together.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_198.jpg
JOHNNYMACDIVER
Thank you! Thank you! Thank you! I did not need to remove the steering wheel but everything else was right on!
RACEFAN966
  • 5,029 POSTS
Great glad to hear it. Hope everything is working correctly. If there is anything else just let me know.
JSEG048
Last night I drove my husbands truck for Amish (we live in PA!). When I got to the guys house, I turned the truck back on to leave but the gear shift was stuck. The Amish guy had to help me pull it down to D. I drove the guy to a store and when we were about to leave, the gear shift had the same issue; it was stuck on park. Again he had to help me get it down to drive, by pushing it really hard down to D. So I finally finish up driving for him and get home. I park the truck in it's usual spot and go to turn off the truck, but the key and ignition is locked in the 'on' position. The truck sat there for maybe up to an hour as my husband and I did everything we could to turn it off. We tried moving the wheel, putting it in neutral, tapping the key with a screwdriver; everything. My husband said it was probably my fault because whenever I turn his truck on, I "turn the key too far forward". So I guess his theory is that I turned it too far and it locked up. Now that I type out the whole story, I wonder if pushing the gear shift thingy too hard cause something to happen? I called mechanics and lock smiths and all are confused. We are going to bring it into the dealership tonight or tomorrow for a quote, which I'm really scared about.
Have you ever experienced this before? If you have fixed this issue before, what price did you charge? I understand that you can't diagnose my issue online but I thought I'd at least get some opinions as to what may have happened with his truck.
WRENCHTECH
  • 20,761 POSTS
You probably broke it when you forced it out of park.
That would be called the shift interlock feature. It operates on the same circuit as the brake lights so the first thing you want to do is to make sure the brake lights are working when this problem is present. If the brake lights are working, that proves the circuit is good up to that point, then you'll have to get to the solenoid in the console. Disassemble as much as you have to to access the solenoid near the shifting mechanism. Us a 12v test light to test for power coming and going at the solenoid when the brake is applied. If power is arriving and switching and the solenoid is not triggering, the solenoid is bad and will have to be replaced.
  • 110,190 POSTS
Don't laugh, but are the brake lights coming on? The brake light switch powers the park lock solenoid. If the switch doesn't send power to the solenoid, the shifter will stick in park. Or if are already in gear and want to shift to park, the key won't come out.
JESSI BUNYARD
I tried turning my key off and my ignition won’t turn off.
Just to be clear, will the key remain in the on position or will it go back to the ACC position but just not come out.
If the key will not turn at all and it stuck in the on position, then I suspect the cylinder is the issue.
However, if it is only going to the ACC position but not go to the off position and come out then I suspect you have an issue with the interlock solenoid. However, these are different issues so we need to clarify it first.
If you can get a quick video of this issue that will really help. Thanks
  • 54,334 POSTS
Here is how you can replace the ignition tumbler and lock assembly in the diagrams below. Check out the diagrams (below). Please let us know what happens.
TONELIOUS
I am trying to replace ignition switch but I cant get the new switch or the old one back on actuator rod and lining up with the mounting holes, the rod is to far forward to line up with holes. I am talking about the actual switch not the key switch. what am i missing or doing wrong.
Feb 8, 2021 at 12:25 PM (Merged)
MERLIN2021
  • 17,250 POSTS
IGNITION SWITCH Removal 1. Remove steering column-to-dash panel bracket. Lower steering column. Remove ignition switch retaining screws. Place ignition switch lock cylinder in LOCK position. 2. If cylinder lock was removed, the actuating rod to the switch should be pulled up until there is a definite stop, then moved down one detent, which is the LOCK position. Disconnect electrical harness connectors. Remove ignition switch assembly. See Fig. 1. Fig. 1: Identifying Column Switches Courtesy of GENERAL MOTORS CORP. Installation Place ignition switch in LOCK position. See Fig. 2. Install ignition switch. Ensure actuating rod is aligned with ignition switch. To complete installation, reverse removal procedure. Fig. 2: Identifying Ignition Switch LOCK Position Courtesy of GENERAL MOTORS CORP. NOTE: It is not necessary to remove steering wheel. Ignition switch is mounted on top of steering column, near front of dash. NOTE: Use only specified screws. Using screws that are too long may prevent column from compressing under impact.
https://images.2carpros.com/forum/automotive_pictures/62217_gmc1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_gmc2_1.jpg
74ROD
Interior problem
1990 GMC Sierra 6 cyl Two Wheel Drive Automatic
how do I replace a worn ignition cylinder key switch?
picture instructions greatly appreiciated.
Thanks,
Rod
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the steering wheel. Remove the turn signal switch. It is not necessary to completely remove the switch from the column. Pull the switch rearward far enough to slip it over the end of the shaft, but do not pull the harness out of the column. Turn the lock to Run. If necessary, remove the ignition key. If equipped, remove the buzzer switch assembly. Remove the lock retaining screw and remove the lock cylinder. WARNING If the retaining screw is dropped on removal, it may fall into the column, requiring complete disassembly of the column to retrieve the screw.
https://images.2carpros.com/forum/automotive_pictures/261618_1_202.jpg
To install: Rotate the key to the stop while holding onto the cylinder. Push the lock all the way in. Install the screw. Tighten the screw to 40 inch lbs. (5 Nm) for regular columns, 22 inch lbs. (2.5 Nm) for tilt columns. Install the turn signal switch and the steering wheel.
