2CarPros - Car Questions & Answers
GMC Other Repair Question
Topics covered: Oil leak, Motor oil, Transmission.
Asked on March 5, 2006
Engine oil leak
:evil: i have oil leaking from the transmition bell housing. i have a idea that it is my rear main seal. but want a secound oppinion.
can anyone agree with me or does anyone have any other ideas :?:
thanks
Avatar Asked by 250rigid
Answer
Replied on March 5, 2006
Are you 100% sure it is motor oil leaking from that area? Transmission fluid can be leaking there as well. Rule of thumb: Reddish looking fluid is transmission, Blackish is oil. After your daily drive, place a fresh piece of cardboard under the leak area. Whatever is leaking will stain the area fairly soon.
If it is your motor oil leaking, make sure you check and add oil to proper level often. You do not want to create an additional problem because of lack of oil.
It may not necessarily be the rear seal. Also check that your oil pan is not leaking around the edges, especially at the rear of engine. To see 100% you must remove the torque convertor cover.
Good luck, let us know what the outcome is.
Tiny Answered by kenvcr
2 questions asked
