Mechanics
HEATER CORE REMOVAL
2000 GMC Jimmy
Heater problem
2000 GMC Jimmy 6 cyl Four Wheel Drive Automatic
How do you seperate the heater box from the firewall. I've removed the hoses, and the one 10mm nut on the ext. Side of firewall and 10mm bolt from bottom of heater box on the inside. The heater box still feels tight. Is there hidden bolts or does the evap. Box on the exterior side have to be removed. Any help would be great. Thanks
Mike22484
November 14, 2008.
Removal
Remove the HVAC module-auxiliary.
Remove the screws from heater core cover-auxiliary from the HVAC module-auxiliary.
Remove the heater core cover-auxiliary.
Remove the HVAC module pass thru seal-auxiliary.
Remove the heater core-auxiliary from the HVAC module-auxiliary.
Installation
Install the heater core-auxiliary to the HVAC module-auxiliary.
Install the HVAC module pass thru seal-auxiliary.
Install the heater core access cover-auxiliary to the HVAC module-auxiliary.
Install the screws to the heater core access cover-auxiliary and tighten to 18 inch lbs. (2 Nm).
Install the HVAC module-auxiliary.
Bluelightnin6
Nov 14, 2008.
