Ford, Taurus, 1992, 3.0. The problem with this car is that it turns over but just won't start. I've changed the cap and rotor, battery, spark plugs, and wires. Bought a scanner and the codes that came out were the AIR CHARGE TEMPERATURE sensor (atc), ENGINE COOLANT TEMPERATURE sensor (ect) and the TRANSMISSION OIL TEMPERATURE sensor (tot). I have tried spraying some starter fluid in the throttle body but with no success. Want to check the ignition coil and module but don't know how. Don't know what primary and secondary resistance or continuity means. Any ideas or advice would be greatly appreciated. THANKS!
SPONSORED LINKS
Tuesday, February 13th, 2007 AT 6:36 PM
