2002 Ford Taurus Repair Question
Asked on October 11, 2008
2002 Ford Taurus Starter
Engine Mechanical problem
2002 Ford Taurus 6 cyl Automatic 92000 miles
i changed the starter and i changed the ignition switch and it still just clicks what should i do next and how to jump the starter or what kinda wire can i use to jump the starter to make it start
Answer
Replied on October 11, 2008
to jump the starter use a jumper cable, connect the one wire from the relay to the other one that is the same size, about battery cable size.
since its clicking i would check for a weakbattery or one that has corroded or loose connections.
if thats not it then i would be suspecting a bad starter relay/solenoid.
last but not least would be a bad starter. or in rare cases a frozen engine.
