V6 SPARK PLUG SPECIFICATIONS
ApplicationGap In. (Mm)Torque Ft. Lbs. (N.M)
OHV.042-.046 (1.07-1.17)7-15 (9-20)
Friday, January 15th, 2021 AT 10:26 AM
(Merged)
SPARKYTAURUS
MEMBER
1 POST
2005 FORD TAURUS
SEL model, 65,000 Miles, six cylinder 3.0 L. My question is, what is the correct gap size that my spark plugs should be set to? I have checked my engine spec guide and also the sticker guide under the hood but neither specifies what the gap size should be. Please let me know as soon as possible. I have had the emission test ran on my vehicle and now I just need to change the spark plugs. I cannot afford to take my vehicle to the Ford dealership to have them changed. Thank you very much. :)
(Merged)
RACEFAN966
MECHANIC
The gap should be.042 to.046. Should have been on that sticker strange. Use motorcraft or NGK spark plugs.
SPONSORED LINKS
(Merged)
CARMENNL
MEMBER
2005 FORD TAURUS
6 CYL
AUTOMATIC
111,956 MILES
What is the required gap for spark plugs in a 2005 ford taurus se . I purchased some and was told its gapped at 0.44. And the one I removed were gapped at 7.0. Stung by this one help please. No I do not have the manual. And on the sticker under the hood it does not give the gapping just says to look in the book. HELP ME PLEASE. THANK YOU
(Merged)
DOCFIXIT
MECHANIC
Gap.042-.046
(Merged)
CARMENNL
MEMBER
Ok thank you very much
(Merged)
DOCFIXIT
MECHANIC
Welcome
(Merged)
OFFTHEHOOK
MEMBER
1 POST
2002 FORD TAURUS
138,000 MILES
I was told that I would not need to gap platinum plugs. I take the old plugs out put new ones in. New wires then I put the car back together. Try starting the car it turns over but won't start try it again nothing. 2 or 3 more times later I start to smell gasoline. I take a plug out and its dirty and smells like gas.
Friday, January 15th, 2021 AT 10:30 AM
(Merged)
MECHANIC
Check to make sure you are getting a good hot blue snapping spark to the plugs, and make sure the plugs are properly gaped.
(Merged)
1HOT54
MEMBER
1 POST
1998 FORD TAURUS
V8
FWD
AUTOMATIC
78,000 MILES
I bought Motorcraft SP432 plugs for my SHO. Its not a fun job replacing them and I want to get it right the first time. Is this the best plug and what is the proper gap. I keep getting different answers.
SPONSORED LINKS
Friday, January 15th, 2021 AT 10:48 AM
(Merged)
BLACKOP555
MECHANIC
The true gap for your vehicle what was tested is located on the emissions lable, will tell you the recommended spark plug and the gap.
1.07 - 1.17 mm (0.042 - 0.046 in)
iridium plugs are really fancy, as are the platinums. As long as its motorcraft they are good for your car.
(Merged)
DN4192
MEMBER
1998 FORD TAURUS
6 CYL
FWD
AUTOMATIC
127,000 MILES
I want to change out the spark plugs in my 1998 ford taurus station wagon se. Is there a "best" type to use or are they all the same?
Sunday, May 23rd, 2021 AT 11:43 AM
(Merged)
MECHANIC
Use OEM part no. AGSF 32F M
(Merged)
DN4192
MEMBER
So I should stay away from the non ford plugs? How are the ones you recomend different from say champion, Bosch or those you can get from a auto parts store? Also what about the wiring?
(Merged)
MECHANIC
Get all your ignition components part original don't get tempted with other stuffs-this is my opinion
