2CarPros - Car Questions & Answers
Ford Ranger Repair Question
Topics covered: Sensor, Coolant, Dealer.
Asked on December 25, 2006
PINGING NOISE
I have a 99 ranger, it pings most of the time especially when warmed up.. v-6 3.0 i run premium it helps a bit.. whats the problem? :?
Avatar Asked by shiningstar
Answer
Replied on December 26, 2006
Since that vehicle doesnt have an octane shorting bar, i would guess mixture control problem or EGR problem.Either way its probably running lean when warmed up.A new fuel filter and tune up is a basic place to start,but it might require in-depth diagnosis.Could be the fuel pump, coolant sensor, Mass Airflow Maeter, etc
Tiny Answered by 2CarPros Jack (expert)
12,033 answers provided
For what it matters. Ford has a revised MAF sensor or EGR valve for the pinging problem-I don't recall which. They also have an updated computer for the pinging. However, A Ford source tells me that it doesn't always work :?
Tiny Answered by Service Writer (expert)
9,955 answers provided
Replied on December 31, 2006
I had an issue with my 94 Taurus pinging, all systems checked out, comp was healthy 160 across all cylinders, what I ended up doing was dumping a couple of cans of GM Top Cleaner into the upper end through the vacuum lines and let it sit for an hour, fired it up smoked like an sob for a while, poof ping is gone.. I'm thinking possible dirty intake valves.. Ford Dealer also told me that ping is an issue, not always solvable,, but this solution worked for me.. I think Ford makes some type of intake cleaner also..
Tiny Answered by TaurusWheel
4 questions asked
