4 Wheel drive wont engage
GPKNIVES
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • 94,000 MILES
I just bought a ford ranger 4 wd today from a dealer. When I test drove it, everything worked. I went to take my wife for a drive and the 4 wheel drive lights (low and high) kept flashing as I drove. I stopped and attempted to put the car in 4 wd and it would not engage. Please help me.
Friday, January 22nd, 2010 AT 10:57 PM
  • 108,320 POSTS
It sounds like you have the same type of luck as I do. Have you checked for power to the actuator on the transfer case? (Can you hear the actuator shifting when you select 4wd?) Also, check the vacuum hoses going to the front axle near the hub assembly. Make sure they're in good condition and not damaged.
Since you just got the truck, won't the dealer help you with this?
Sunday, January 24th, 2010 AT 1:13 AM
SIRLAGS
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • 83,000 MILES
The 4wd high light comes on but the 4wd low doesnt, 4wd doesnt engage in either case. Had some problems last winter with it engageing intermitantly. When it did it wa an audible thud you could hear and feel.
Monday, January 13th, 2020 AT 7:29 PM (Merged)
  • 108,320 POSTS
It sounds like the actuator is going bad. It is the electric motor on the transfer case that engages the 4wd. When this happens, check to see if there is power to the actuator. IF there is, chances are it is bad.
Let me know what you find.
SKOOTCHY
  • 1998 FORD RANGER
98 ford ranger 6 cyl 5 spd 120,000 mi. The yellow 4wd indicator lights on dash come on when I start the veh and then turn off like the rest of the start-up lights. When I turn the knob to engage the 4wd nothing happens, it stays in 2wd. 4wd does not engage (High or Low) and regardless of the position of the 4wd knob the 4wd indicator lights on the dash occasionally flicker while I drive. However when they flicker, that is all that happens, there is no 4wd activity or noises to indicate something is trying to happen. I checked all the fuses near the door panel and they all look good. Could it be the switch itself?
98RANGERXLT
  • 301 POSTS
How do you go into 4wd.
SKOOTCHY
I turn the selector knob on the dash so it's pointing at 4wd high. This is done while the vehicle is stopped. Bought the vehicle used last winter and it worked fine for most of the winter then one day it didn't work anymore. :(
TRUCKNUT
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 136,000 MILES
I have a 1998 ford ranger 4x4 with a 3.0 liter engine. Today I was driving it home when I noticed the four high and four low indicator lights on the dashboard will blink a few times and then stop for two minutes and then start up again. I tried to put it in four wheel drive but it wont go into either one. I recently had it inspected and I also had to disconect the battery a few days before, could this have caused a code to reset? Pease help, thanks.
MERLIN2021
  • 17,250 POSTS
You need to have the code(s) read, Autozone does it free, then post the results. Check the vacuum lines to the hubs and see if one broke or came off somehow.
ALICIA77
  • 1998 FORD RANGER
1998 Ford Ranger
i have sent my truck to a mechanic twice because my four wheel drive is not locking in they thought is was the valve but it is not they tried the part and still did not work. What could this be.
MERLIN2021
  • 17,250 POSTS
Have them check for vacuum hoses to the wheels, if it has the vacuum, check for vacuum leaks. Check the hose for vacuum, trace back to origin on motor, and repair or replace the hose.
DASHDOG
  • 1998 FORD RANGER
I have a 1998 Ford Ranger 3.0L with 108000 miles. I have been having problems with my 4wd working. The problem is that the 4wd will not engage and when this happens the 4x4 high and low dash lights flash on and off about 8 times or so. The lights continue to do this every 5 minutes or so. This is not the first time this has happened to me, but last time the problem went away. Any ideas as to the problem? Also any estimate at what it would cost to fix? Thanks alot.
MUSTANGDOS
I found this question elsewhere...Looks like it is a good start...
https://www.2carpros.com/forum/problem-with-the-4-wheel-drive-vt24532.html?highlight=explorer
SERVICE WRITER
  • 9,123 POSTS
There is another one that is identicle also:
https://www.2carpros.com/forum/1998-ford-ranger-4x4-vt24225.html?highlight=4wd+ranger+lights
The fix was never said though. I would pm or email both of them to see how they made out. I couldn't find anything about the flashing lights. Scary part is I own one too!
HAMBIKER
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 88,000 MILES
I have a 1998 Ford Ranger extended cab with 4x4 and the 3.0 liter 6 cyl and 5 speed manual transmission. After one week of ownership and driving on a lot of snow and ice the 4x4 no longer engages. The indicator lights for 4HI and 4LO flash together 6 times every few minutes and truck stays in 2WD no matter where you put the knob on the dash. Found no blown fuses. Could this be the actuator motor for the transaxle or probably the automatic hubs?
2CARPRO JACK
  • 11,533 POSTS
Ford has issues with both the GEM module and the 4x4 control module, the latter of which is cheaper.I have seen both fix a problem that you are describing. When you say dash light do you mean all of them or just the 4x4 indicators? If all th elights I might lean toward the GEM odule, just 4x4 lights, the 4x4 controller
2CARPRO JACK
  • 11,533 POSTS
Most likely the motor on the transfer case. There seems to be a bit of a problem with them, have seen several posts with the same problem
BRT3338
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • 12,500 MILES
Hello. I have a 98 ford ranger 4X4 with 125,000 miles. Just recently, my 4whell drive won't work. I turn the switch and the dash light comes on, but the front tires won't go. I then shift the transmission to neutral and switch it into 4 low, I can feel it change into low but the front tires still won't spin. Is it the hubs?
JAMES W.
  • 2,394 POSTS
If you have lockout hubs, this is most likely your problem. One of your hubs could be hung up. You can check by putting the T case in FWD and jacking one front wheel. Turn the lifted wheel. If the lifted wheel turns, but the axle shaft doesn't. Your problem is in that wheel. If the shaft on the other side turns, the problem is in the oposite wheel. IF, the drive shaft to the transfer case turns, your not in FWD and the problem is in the T case. Hope this helps.
1CATWOMAN1
  • 1998 FORD RANGER
  • 3.0L
  • V6
  • 4WD
  • MANUAL
  • 225,000 MILES
I used my four wheel drive on my 98 ford ranger like a month ago worked fine then a week later I went to use it again and the 4hi and 4lo lights started flashing and hasn't worked since. Been trying to figure out if its the switch or transfer case. I checked all the fuses and they're all fine. And it seems like everyone has a different answer for what's wrong with it. And I don't wanna just go out and by random parts and play a guessing game. Oh and I remember when I put on my manual lock hubs on it a couple of years ago I plugged off one of the vacuum hoses so I unplugged it and put it back where it originally was and now the four wheel drive lights stopped flashing but it still wont go into 4hi or 4lo. So what could the problem be? Its a older truck with 225,000 miles on it but it runs and drives really nice and is in really nice shape with very little rust. I've taken very good care of it and wanna drive it till its completely retired.
HMAC300
  • 48,601 POSTS
Scan for codes first a pro may have to do it. Check items in pic as well.
