ABS light
2006 FORD FREESTYLE
121,000 MILES
DDANIELS
The speedometer will stop working and the abs lights will come on why? this happens off and on?
Dec 20, 2011 at 12:09 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
This sounds like a classic vehicle speed sensor that has gone out. Here is a diagram below of the sensor location.
You may need to lift the car to replace it, here is a guide so you do it safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
The sensor looks like this (below) and it is located near the passengers side CV axle where is comes out of the transmission
Please let us know what happens so it will help others.
Cheers, Ken
Aug 21, 2017 at 9:14 PM
RYH JONES
2006 ford freestyle sel--traction control light on dash comes on and stays on..went tru water and then tc light and abs light came on and both stay on, now one day later wrench icon comes on slight******** when going from park to reverse...what is going on?
Aug 21, 2017 at 9:14 PM (Merged)
DAVE'S BIG BACKYARD!
  • EXPERT
  • 262 POSTS
omg what a mess.well first thing first,you need a good scanner and go from there,but to me it sounds like a abs control module is going bad due to wires being exsposed to water,where i dont no im just tring to help.
BBUESCHER
Computer problem
2006 Ford Freestyle 4 cyl Front Wheel Drive Automatic 60000 miles
Upon replacing Left Front wheel bearing, ABS light on...Will the computer reset itself and turn this light off. I think the speed sensors are clean.
WRENCHTECH
  • 20,761 POSTS
No, the system resets every time the ignition is turned off. There is a hard failure in that sensor so something must have been damaged or misaligned in the process.
