cam position sensor ?
2007 FORD F-150
206,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
TODD ELLINWOOD
can the sensor variance be done by me or is it dealer only?
Sep 7, 2019 at 1:39 PM
SCGRANTURISMO
  • CAR REPAIR CONTRIBUTOR
  • 4,897 POSTS
What sensor variance are you talking about? Camshaft sensors usually read a wheel on the end of the camshaft to give the Power-train Control Module (PCM) information on where the camshaft is in it's cycle.
Thanks,
Alex
2CarPros
Aug 21, 2020 at 2:53 PM
TODD ELLINWOOD
I installed a new cam position sensor and was told I need to perform cam variance. now was also told it was a dealer only procedure Ford computer software.
TODD ELLINWOOD
now that I have installed new camshaft position sensor is there a procedure that needs to be performed to reset it?
BMDOUBLE
  • 1,139 POSTS
No, just clear any trouble codes that have been set and you're good to go. Ford senior master technician, 27 years dealer tech.
PATRICK ROONEY
I need to know or find a picture to where my camshaft position sensors are located. I got the P0345 code today and after every other start I get the code. Thanks!
Aug 21, 2020 at 5:38 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
I have included the information you requested in the diagrams below.
Thanks,
Alex
2CarPros
PATRICK ROONEY
Which side is P0345 on? Or should I just change them both out?
SCGRANTURISMO
  • 4,897 POSTS
I have included a diagram down below in the diagrams for you. I have marked the bank with an "X". It is going to be the driver side bank as you sit in the vehicle.
Thanks,
Alex
2CarPros
TOMMYGUNZ06
truck runs fine but i get a camshaft position sensor circuit malfuction bank 2
Aug 21, 2020 at 5:39 PM (Merged)
RACEFAN966
  • 5,029 POSTS
Ok what is the code number that is found? This will lead me to the test procedure to that code. Get back to me with the P code you found so I can look it up and walk you through the test. Thanks.
MMOWER
I ran the trouble code for my truck and apparently, I need to replace the camshaft sensor. Where is it located?
Aug 24, 2020 at 9:22 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
It has two of them, they are on the front of both heads. The picture is the left side. https://www.2carpros.com/images/external/118853912.gif
2CP-ARCHIVES
  • 4,540 POSTS
Where is the cam sensor located on a 2005 5.4l v8 Tritan motor
HMAC300
  • 48,601 POSTS
There are two sensors one on each cylinder head at the front here is a guide that will walk you through the steps with a diagrams below that shows you the location on your engine.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
PHILLIPSG148
Replaced vct solenoid and cam sensor still makes deasil sound on idle and a 0012 code
HMAC300
  • 48,601 POSTS
there is a tsb on this for your problem the number is 14-0114 dated may 30, 2014. call a dealer and see if they will do it for free they may see pic
JOHN PAIGE
Truck started to run badly code said bank 2 cam retarded. put new phasers, CVT solenoids, and cam sensors, but it still runs the same and throwing same code.
STEVE W.
  • 15,158 POSTS
Check the actual oil pressure with a mechanical gauge, you need at least 30 psi at idle that stays steady to keep the system working. Next check the oil flow to the top end, these engines like to sludge the passages to the phasers. Put a good scan tool on it and check the cam/crank timing. A bad chain or tension-er will set this code.
DIJEFFZ
I replaced the sensor and the check engine light came back on. thinking that maybe I did not know left from right I replaced the other sensor, but it still came back on. is there something else that I might be able to check?
WRENCHTECH
  • 20,761 POSTS
The code doesn't automatically mean the sensor itself is the issue. It can be any part of the circuit to include the wiring and PCM or even mechanical issues preventing the sensor from reading properly. It all needs to be looked into.
