post the code(s) you get here and i will follow up.
SPONSORED LINKS
Wednesday, November 3rd, 2010 AT 10:27 PM
CHRISCASTRO
MEMBER
1 POST
2006 FORD F-150
V8
4WD
AUTOMATIC
108,000 MILES
Engine light currently on. In cool weather truck runs well, but when it gets hot the truck really surges and sputters. Any ideas?
Wednesday, September 9th, 2020 AT 5:24 PM
(Merged)
MECHANIC
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
(Merged)
REDHAT9
MEMBER
2006 FORD F-150
V8
4WD
AUTOMATIC
43,000 MILES
Trouble starting. After about 3 cranks of the engine it starts after the 3rd. Check engine light recently came on because of this. What could issue be?
(Merged)
BLUELIGHTNIN6
MECHANIC
Since the engine light is on the best thing to do is just take it to a local auto part store and ask them to retrieve your vehicle's trouble code(s). This should pinpoint the culprit.
SPONSORED LINKS
Wednesday, September 9th, 2020 AT 5:25 PM
(Merged)
REDHAT9
MEMBER
Had to end up doing that.
Truck still runs fine.
Error code turned out to be a mis-fire code.
Have to replace the plugs and hope none of them break before it its done.
Thanks for the response
(Merged)
BANDDAD
MEMBER
2006 FORD F-150
6 CYL
2WD
AUTOMATIC
126,477 MILES
After you start the truck, when you shut it off, you have to wait about ten second for the check engine light to come back on. Will not pass inspection.
(Merged)
MECHANIC
I'm not sure I understand. Is the light off when the engine is running?
(Merged)
BANDDAD
MEMBER
The check engine light go off when it running.
What I have found out is that this will happen after you rest the the computer or unhook the battery.
Until the computer goes through all it test.
Drove the truck all day yesterday and have two more incomplete, hopeful it will clear today.
Thank You
(Merged)
MECHANIC
Have you checked for codes?
(Merged)
P SCHILLER
MEMBER
2006 FORD F-150
V8
4WD
AUTOMATIC
80,000 MILES
5.4 liter ford engine light on with engine icon. Does not overheat. Oil pressure guage shows correct pressure. When running to long engine will shut down. What could be wrong?
Wednesday, September 9th, 2020 AT 5:26 PM
(Merged)
BLUELIGHTNIN6
MECHANIC
Since engine light is on best thing to do is retrieve trouble code(s) that are stored by vehicle's computer, most local auto part stores will do this for free of charge. Post the code(s) you get and I will follow up
SPONSORED LINKS
(Merged)
P SCHILLER
MEMBER
Thanks. I will get back to you
(Merged)
BUYHARDWARE
MEMBER
1 POST
2006 FORD F-150
4.2L
2WD
MANUAL
52,000 MILES
Did a rear brake job this weekend. When got done the engine light was on
(Merged)
CARADIODOC
MECHANIC
The place to start is by reading the diagnostic fault code. That will indicate the circuit or system that needs further diagnosis. Many auto parts stores will do that for you for free.
(Merged)
JEREMYTR
MEMBER
2006 FORD F-150
V8
4WD
AUTOMATIC
45,000 MILES
My truck was fine, I pulled into local car wash and washed it off including underneath because of salt and grime being winter and all. I got in to leave started the truck put it in drive and truck did not want to go, check engine light came on, checked error codes and I have p0731 and p0732. Any ideas?
(Merged)
KRSKI
MEMBER
According to my Actron scan tool the Code 731 is a Gear 1 ratio is incorrect. Code 732 is a Gear 2 Ratio is incorrect.
(Merged)
JEREMYTR
MEMBER
Thanks Krski, I should have mentioned that I know what the 2 codes are. I just don't know why 1st and 2nd gear quit working at the car wash. Is there something that could have come unplugged or failed that is simple and I'm overlooking. If the speed sensor went bad would this happen? Being that the truck is just out of warranty I was hoping to find something that I could fix.
(Merged)
KRSKI
MEMBER
The car wash may just be a coincidence. Although the wire harness going to the tranmission may also have shorted from the water spray. IDid you try to clear the code and see if the MIL turns back on. Are you having any apparent problems with the transmission. I have a feeling that it is an electrical bug.
(Merged)
SKIDS86
MEMBER
2006 FORD F-150
V8
4WD
AUTOMATIC
57,000 MILES
I have a 2006 f-150 that was purchased recently and my service engine light appeared on in route from work the other day. I have a obd2 engine checker that has been useful for many years, but it will not work on this truck, it flashes 8s (malfunction) when attempting to scan. The truck has a intercooled roush supercharger installed on it and I know the pcm was sent to them for re-programing as part of the supercharger install. I'm wondering if this has anything to do with the issue or is the truck running off a different system that my scanner is not compadible with?
(Merged)
