1990 Ford F-150 Repair Question
Topics covered: Distributor, All wheel drive, Battery.
Asked on April 30, 2009
F150 cant start f150
Electrical problem
1990 Ford F150 V8 All Wheel Drive Automatic 158000 miles
I have a 1990 Ford f150 158,000 miles that I can't get started. The truck turns over but there is no Spark. The alternor has charge. Put in a new battery, plugs, wires, distributor cap, rotor in cap, coil and a part i dont remember the name( it's on the side of the truck and the positive and negative cables are connected to it). Any suggestions on what to do next to get it started? Starter? Timing chain?
Answer
Replied on May 2, 2009
Most likely an ignition module.Those are very toughy and go out for no real reason.Should be mounted to the side of the distributor where the electrical plug goes.You must disconnect ehneg batttery cable before replacing it or you may burn up the new one
Replied on May 13, 2009
cheack the eec reley under the hood drivers side
