Engine Oil Pan Removal
BECKEETLESS
  • FORD F-150
How do I remove the oil pan in my 2002 Ford F-150 V6 4.2 Liter. I need your help can you please give me instructions and step by step diagrams please? I love this site.
THANKS!
Thursday, January 18th, 2007 AT 10:15 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,262 POSTS
You must raise the engine up to get the pan out. Here is a safe way to raise the truck
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
The best way is to jack up the engine so that you can unbolt it from the bottom and have enough room between the engine block and the crossmember to remove it.
Disconnect the exhaust, unbolt the engine mounts, unbolt (or at least loosen and back off) the transmission mounting nuts, unbolt the fan shroud and drape it over the fan, (can't really get it out unless you remove the fan as well) and then some models require you to remove a few components on top of the engine so that you are able to jack the engine up the necessary five or six inches to clear the crossmember.
You can then unbolt the oil pan, reach in, unbolt the oil pump and pickup tube, drop those into the pan and haul the pan out of there. I hope this helps.
Don't forget to drain the oil beforehand.
Here are some guides from the repair manual (below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Thursday, November 9th, 2017 AT 2:24 PM
LCPLMATT
  • 1915 FORD F-150
I have an 01 ford f150 4x4 with a 5.4 v8 and 80,000 miles. I need to change out the oil pan but have heard to drop it out you have to jack the engine up being that the front of the oil pan almosts rests on the front diferential and can not drop out. Is this true or is there and easier way to drop this pan out.
Thursday, November 9th, 2017 AT 2:25 PM (Merged)
INDYUKE
  • 416 POSTS
That is true. You must unbolt the engine mounts, loosen the transmission mounts and jack up the engine about five to six inches. Also I think the starter needs to be removed.
JWOOD60379
  • 2001 FORD F-150
  • 6 CYL
  • 200,000 MILES
Engine Mechanical problem
2001 Ford F-150 6 cyl Two Wheel Drive Automatic 200000 miles
How hard is it to replace the oil pan seal. I have had the rear main seal replaced and the the shop says that I need to replace the oil pane seals.
WRENCHTECH
  • 20,758 POSTS
It's a 2-3 hour job but much easier if you have a lift. You will also need an engine support tool.
MYFORD95
  • 1995 FORD F-150
1995 Ford F150 V8 Two Wheel Drive Automatic
Is it neccesary to pull the motor on a 1995 f150 5.0 to remove the oil pan? What is the easiest route to go?
Thursday, November 9th, 2017 AT 2:26 PM (Merged)
  • 31,937 POSTS
Hi there,
See text for sump removal.
mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_1_35.jpg
MO123456
  • 1992 FORD F-150
1992 Ford F150 6 cyl Two Wheel Drive Automatic
how do you remove the oil pan to change the oil pan gasket
  • 31,937 POSTS
Hi there, oil pan R&R instructions.
mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Capture_13.jpg
KELLYFULLER6
  • 2001 FORD F-150
  • 6 CYL
  • 15,000 MILES
2001 Ford F150 6 cyl Two Wheel Drive Automatic 150, 00 miles
how much should I have to pay to replace oil pan? Was quoted $60.00 for parts and $600.00 for labor
BLUELIGHTNIN6
  • 16,542 POSTS
That's a pretty average estimate for your vehicle's oil pan and gasket replacement..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_892.jpg
SHAWNBOBBIE
  • 1995 FORD F-150
  • V8
  • 4WD
  • 139,000 MILES
1995 Ford F150 V8 Four Wheel Drive Automatic 139000 miles
My oil dip stick broke off at the oil pan is it hard to replace? What does it take to fix it? I need to drive it for work will anything happen if I need to get the money to repair it what will happen if anything if I drive it
  • 108,348 POSTS
THey are easy to replace. They simply are bolted to the engine block. Once the bolt is removed, it will pull out. There is an o-ring where it pushes back into the engine. If it is broken, just check to make sure nothing is leaking from it when you run the engine. That is the worst thing that could happen.
Thursday, November 9th, 2017 AT 2:27 PM (Merged)
EWINFREY
  • 6 POSTS
  • 1994 FORD F-150
  • 6 CYL
  • RWD
  • MANUAL
  • 225,000 MILES
I raised motor put blocks under motor mounts, its high enough to get pan out but cant get it past transmission housing. I removed the oil pump pick up line still cant clear trans. Housing. I raised the transmission up also, removed trans. Mount but not enough. Is there another option other than removing transmission
CARADIODOC
  • 33,760 POSTS
I have come across this before. You will have to jack up the engine to gain the clearance necessary to remove the oil pan. There is a post up top that as a bunch of diagrams that will help you in this process.
SQUIRRLY STERLY
  • 1994 FORD F-150
1994 Ford F150 V8 Four Wheel Drive Automatic
what do you have to do to change the oil pan in a 1994 ford f150 5.0 liter 4 wheel drive?
BMRFIXIT
  • 19,053 POSTS
OIL PAN
Removal
Remove fan shroud.
Remove upper intake manifold.
Remove front engine mount-to-frame nuts and raise engine.
On A/T models, disconnect oil cooler lines from radiator.
Disconnect exhaust pipes from exhaust manifold.
Drain engine oil.
Support transmission and remove transmission crossmember. Remove oil pan bolts and lower oil pan.
Remove oil pump bolts and pick-up tube nut.
Lower oil pump assembly into pan.
Remove oil pan from vehicle.
Installation
To install, reverse removal procedure. Apply silicone sealant at front and rear corners of oil pan surface and cylinder block, and where timing chain cover meets cylinder block. To install remaining components, reverse removal procedure.
WST
  • FORD F-150
I have a 94 ford f-150 with a straight six with 147,000 miles on it. The oil pan needs replacing and I found when I unbolted it that it would not come out becouse it cannot fit by the transmition one way and the other the deep part cannot fit over the frame for thee front supension and axel. I have been told that I might be able to undo jest one engin mount and jack up the engin. Any help would be appreciated. Thanks
Tuesday, April 14th, 2020 AT 12:36 PM (Merged)
TEMPO NIGHTMARE
  • 5 POSTS
Hello
Sometimes just disconnecting 1 motor mount will usually do the trick. However, undoing both and raiseing the whole motor maybe a better benefit to easy removal and replacement of the oil pan. Just becareful when doing so. So as to not breaking any other components.I know with GM's the distributor is in the rear of the motor. But since this is a straight six that shouldnt be a problem. Just be sure nothing else is crushed or damaged in the process.
Good Luck!
Let me know the end result. And please dont forget to donate to the site. Thanks!
BIGO
  • 36 POSTS
  • FORD F-150
I havea 89 ford f150 2wd automatic 189000, my rear main seal went out on it an im ready to change it by dropping the tranny, an oil pan, but it looks close considering the oil pumpis all the way to the bottom of the oil pan, I DO NOT WANT to drop the trans start to drop the oil pan then find out ill need to pull the motor any way to get the oil pan off its a 351 windsor, c6trans, 2wd. Is what I REALLY NEED TO KNOWIS IF ANYONE HAS PULLED THE OIL PAN ON ONE OF THESE TRUCKS WITHOUT PULLING THE MOTOR as I would rather do 1 or the other not both. But like I say I think it will clear and abouit half a dozen of my pals think it will but I would give my eye teeth to the guy who said yes ive pulled the pan without pulling the motor or to say you will need to pull the motor to get the pan off I f any one knows for sure PLEASE LET ME KNOW agin its a 89 f150 351 windsor, c6 trans 2wd thanks a million
