Firing order?
2006 FORD EXPLORER
6 CYL • 4WD • AUTOMATIC
AARONCOLLIGNON
need to see a diagram of correct spark plug order for a 2006 ford explorer?
Jan 13, 2011 at 1:00 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
Here is the firing order for both engine in case someone needs them both. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 13, 2011 at 1:36 AM
LGREZA
My son changed out my plugs/wires and he believes he put in same order but my engine turns off it also has a smell to it. I just want to make sure they are in the correct order.
Mar 13, 2021 at 6:14 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
https://images.2carpros.com/forum/automotive_pictures/561653_Firing_order_04_Explorer_40_1.jpg
  • 54,346 POSTS
Here is the firing order for both engines.
V8 Firing Order: 1 3 7 2 6 5 4 8
V6 Firing order: 1-4-2-5-3-6
I included the diagrams below that include the Mountaineer firing order because while they are the same firing order the coils are numbered different. If you don't have the wires on the coils correct then the firing order will be off.
Please let us know if you need anything else.
Cheers, Ken
JDOG45211
i need to now the firing order for my 2000 ford explorer. a diagram would help.
Mar 13, 2021 at 6:15 PM (Merged)
DLOBI
  • 125 POSTS
Starting on the passenger side from grill towards firewall is 1 2 3 4.
Drivers side grill to firewall is 5 6 7 8.
If you need to know coil pack wire position, I need to know if it is a 4.6 or 5.0 liter.
VICKICOX2001
I have the vehicle listed above with a 5.0L engine. I changed my spark plugs and cables now the SUV shakes when I start it. Could you please give me a diagram of the firing order? Thank you so very much.
DOCFIXIT
  • 18,828 POSTS
Here is the firing order for you engine. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
