1997 Ford Explorer Repair Question
1997 Ford Explorer throttle body removeal
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic 207360 miles
trying to remove throttle body
Answer
Hello –
Sorry, the manual doesn’t provide much info on TB removal or installation. Here is what we have.
THROTTLE BODY
Removal
1. Remove air cleaner and duct assembly. Disconnect accelerator cable from throttle lever. Disconnect cruise control actuator (if equipped). Remove accelerator cable bracket and set aside.
2. Disconnect electrical connectors and vacuum lines as necessary. Remove 4 bolts (or screws) retaining throttle body assembly to intake manifold. Remove throttle body.
Installation
Clean gasket mating surfaces. Clean and oil bolt threads. Install NEW gasket. Tighten bolts to specification. See TORQUE SPECIFICATIONS . To complete installation, reverse removal procedure.
If you need more info please tell me your engine size in liter and the 8th digit of your VIN.
Thank you very much for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
