Window not working correctly?
2010 FORD EXPEDITION
107,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MACGYVER52
The cable on the passenger side broke that pulls it back up, how do I fix it as I can not see where it attaches
Aug 30, 2014 at 6:13 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
The cable needs replaced which is the window regulator here is a video to show you how
https://youtu.be/oNxstjcA25k
Aug 30, 2014 at 7:29 PM
MACGYVER52
Yep, did it works great nice site and video btw.
Aug 31, 2014 at 3:41 AM
GREYFOX503
how do i change out drivers side window regulator, do you have pictures of it?
Jul 21, 2020 at 5:36 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sorry for the delay, somehow your post got shuffled to the bottom of the list. First remove the inner door panel (see pic for attaching points)
https://images.2carpros.com/forum/automotive_pictures/1639_ford_1_1.jpg
Then remove the speaker and inner door handle from door. Unbolt the window clamps on the regulator (see pic)
https://images.2carpros.com/forum/automotive_pictures/1639_ford2_1.png
The regulator is a large assembly, so you will have to unclip all wiring from it and work it out from behind the harness.Unbolt and remove regulator (see pic for reg mounting bolts)
https://images.2carpros.com/forum/automotive_pictures/1639_ford_3_1.png
DLS57
I just installed new regulator, now in the process of putting back together and the window is not where it belongs.maybe not lined up ?
  • 54,354 POSTS
The window will set itself. Put it up as high or as low as it will go. Then disconnect the the battery and let is sit for 20 minutes, then reconnect the battery this should reset the initialization.
Also make sure the new regulator is not bound up. I has seem new ones out of the box defective.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
2CP-ARCHIVES
  • 4,540 POSTS
replaced passenger front window regulator. replaced driver and passenger front window motors. al so replaced drivers side master switch. when u press the window switch it just makes a humming sound. used all motorcraft parts. checked all fuses. out of ideas.
WRENCHTECH
  • 20,761 POSTS
Did you replace all those parts trying to correct the same problem?
What window are you having a problem with and from which switches?
Is the window trying at all. What type of noise is it making?
IZZI131
my motor burned out and I want to roll up the window manually
Jul 21, 2020 at 5:37 PM (Merged)
  • 31,937 POSTS
You will have to remove the door trim, disconnect the window motor and push the window up and chock it with a length of timber.
SATURNTECH9
  • 30,869 POSTS
Just to add to this one you could try removing the inner door panel and tapping on the window motor with a hammer while rolling the window up.Sometimes you can get the windows up that way.
IZZI131
if the window regulator cables are sheering would that stop the window from moving up and down
MAFREIRE
On my 2005 expeition, turning on lights or turning on ac triggers rear window latch and at the time if feels like the battery is being drained. Sometimes it even stalls.
HMAC300
  • 48,601 POSTS
both the headlight and doorlocks which is lift gate use the same ground behind right kick panel. that can be loose or a bad ground to the body altogether from the battery. they also use the same fuse.
FIXITMR
  • 9,990 POSTS
could be a fusebox, BCM, or wiring issue. anything done to vehicle just prior to this starting to occur?
MAFREIRE
Thanks for the help gentlemen. The question posed by fixitmr has 2 answers. The battery was replaced 2 weeks ago and the ac evaporator was replaced 8 days before this started happening. The vehicle also needs a new compressor as it is only running at 50% and the intial back window latch trigger issue initially began when I turned on the ac and the compressor kicked in. It has now moved on to the door locks and the head lights.
IRVY76
My drivers side window will go down like normal but will not go up or creep up very slow and stop before its all the way up? What does this problem sound like? Thank you
  • 110,190 POSTS
It sounds like a bad switch. Check voltage to the motor and see if it is less than 12 volts when you put it in the up position.
Let me know what you find.
GHARDUBY
The window rolls down finw but rolls up very slowly. In the winter it seems like it is not going to make it.
SATURNTECH9
  • 30,869 POSTS
You have a weak window motor or binding up window glass.You will have to remove the inner door panel unhook the window glass from the window regulator and see if the window goes up without binding by hand.Its most likely a weak window motor though.
BRADENLEG100
The power window for my front passenger window works perfect when controlling (up or down) from the front passenger door controls, however, when I try to control from drivers side, I can get window to roll down, but the up function does nothing (no noise and appears that there is some sort of disconnect). It is inconvenient because we always have to use the front passenger door control to get window to roll back up (it's a pain when I am driving by myself). I am thinking this is an issue with the drivers side main control panel switch or relay or maybe the contacts, but maybe I just need to do a default reset if that is applicable (car battery was changed recently). If it is a switch or relay, can you please let me know how to change and which one. Thank you! Steve
Jul 21, 2020 at 5:38 PM (Merged)
HMAC300
  • 48,601 POSTS
it 's probably the master switch because you don't use the one touch down feature with passenger operation. I'd have a pro check it first however it may be just the switch
NOBIKINI21
Driver side window will not come back up, how can I get it back up , untill I can take it to the shop. I suspect that the switch is bad.
NOBIKINI21
[quote:e19b5e843f="nobikini21"]Other Category problem
2003 Ford Expedition V8 Two Wheel Drive Automatic 70000 miles
Driver side window will not come back up, how can I get it back up , untill I can take it to the shop. I suspect that the switch is bad.[/quote:e19b5e843f]
FASTEDDIE100
Electrical problem
2003 Ford Expedition V6 Front Wheel Drive Automatic 38000 miles
The power window switch located on the driver side rear door panel does not work completely. I can get the window to lower, but it will not close using this switch. However, I can raise the window by using the main window controls located on the driver door panel. It don't think it's a motor problem because of this. Could it be a wiring or a fuse problem that will not allow the window to be raised by the switch on the rear driver-side door?
MERLIN2021
  • 17,250 POSTS
I think you have a switch problem at that door...
FASTEDDIE100
Merlin. thanks for the reply. I pulled the switch out to clean and inspect it. There wasn't anything mechanically wrong with it from what I could see. After I re-connected the switch without putting the panel back on, it would actually work sparingly. I don't think it was anything I did, rather just continuing to press the button. Is this a part that I can order from a Ford dealership or a local parts store?
MERLIN2021
  • 17,250 POSTS
Ford will be able to get it, local store maybe, check both...
HINEJ33
Interior lights and running board light along with power windows stopped working. Traced to fuse #14 replaced and it blows right away. Sunroof is not working either, stuck open position.
Jul 21, 2020 at 5:39 PM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
Sunroof is probably the switch. Make sure it is receiving and passing power. Make sure fuse #14 is receiving power. Here is a guide to help you test it.
GREYFOX503
You guys are well worth the donation!! thanks
the drivers side power window just quit,. when I push the up/down switch I can hear the relay clicking.
I have no Idea of how to remove the door panel, or how to replace the motor.
Do you guys have pictures of How to do this??
Thank YOu In Advance!
Bill
2CARPRO JACK
  • 11,533 POSTS
There will be a few plugs on the door panel that hide screws, especially on the door handle. If there are no screws around the edge then the panel will pop off the door. If you start at the bottom you will be able to see under it for the clips. Try to help the panel off by prying next to the clips with a long screwdriver unless you want o buy a panel trim tool.
BCW230
when it rains alot my expedtion's radio, windsheild wipers and windows don't work. and my 4x4 lamp lights up on dash sometimes too. but when i disconnect the battery and reset the master computer every thing works right. until it rains alot again please if someone knows an answer to this lot me know because this is driving me crazy. ford expedtion 2001. thanx
CARADIODOC
  • 34,309 POSTS
Ford has a lot of trouble with windshield leaks that drip water onto the GEM module on the left side of the dash. That applies to the pickup trucks but it's worth considering on your vehicle too.
caradiodoc
DAVIDTALAMANTEZ
My window is in the down position and the motor is burned out. I bought a replacement motor for the window, however, the clearance between the motor and the window is so tight I can barely fit my hand in there to remove it. Is there a way to raise the window so I am able to replace the motor?
  • 110,190 POSTS
Not without removing the track or the motor. Are you sure the motor is bad? Have you made sure there is power to it when you try to put it up? Also, the OEM motor should be rivited to the door. If you remove the rivits, the motor will move and you then can raise the window. (NOTE: I can't remember if there is a coil type spring that can come undone on your year, so be aware of that possibility.)
LEt me know.
REAMAT
my window fell off track and i canot open my door from the inside something is lodge in the way and the door knob wont move
Jul 21, 2020 at 5:42 PM (Merged)
REAMAT
[quote:018d2d292a="reamat"]Interior problem
2002 Ford Expedition V8 Two Wheel Drive Automatic 150000 miles
my window fell off track and i canot open my door from the inside something is lodge in the way and the door knob wont move[/quote:018d2d292a]
JRG9662
Interior problem
2001 Ford Expedition V8 Four Wheel Drive Automatic
the drivers side window has come off the track. how do i remove the panel and fix?
DOCFIXIT
  • 18,828 POSTS
Hi
Can't remember site but Google door panel removal
