Need to adjust parking brake
2002 FORD EXPEDITION
150,000 MILES • V8 • 2WD • AUTOMATIC
JM
  • 56 POSTS
Can't figure out where to adjust the parking brake on a 2002 ford expedition. This car is not like a normal car that I have adjusted. thanks...........
Apr 19, 2012 at 4:06 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Has star adjuster like drum brakes see diagram below.
Apr 19, 2012 at 4:40 PM
JM
  • 56 POSTS
I have 4 way rotors. Not drums. I read somewhere that there is a rubber plug on the backside of dust cover to adjust from. How can I have a drum and a rotor. don't get it,,,,,,
Apr 19, 2012 at 4:52 PM
DOCFIXIT
  • 18,828 POSTS
Inside of rear disc is the drum park brake shoes apply on. if you pull caliper then disc you will see park shoes as in diagram. yes should be plug in backing plate to access star adj
Here is a guide that can help
https://www.2carpros.com/articles/parking-brake-shoe-replacement
Apr 19, 2012 at 4:59 PM
ROYCAR71
  • 359 POSTS
I tried to adjust using this screw but car still roles when in neutral.
Nov 26, 2018 at 4:20 AM
  • 54,354 POSTS
Do you have new shoes? Sounds like they are worn out. This guide can help:
Let me know what happens, Ken
Nov 29, 2018 at 10:31 AM
ERTURKM
Wondering if you can tell me how to adjust the emergency brake. When I push the emergency brake pedal all the way down, it doesn't feel like it grabs much. It's so weak, its almost as if the emergency brake is not engaged. It will grab a little bit, but barely. The truck stops just fine when driving, but if I park on a hill, I like to set the emergency brake to provide additional parking safety. Is there an adjustment setting somewhere that needs adjusting? They are rear disk brakes. I am not sure if the emergence brake is cabled. Any ideas on how to make the brake grab nicely? Again, the brakes work just fine when driving and I use the brakes normally, just the emergency brake grabs very little when parked.
Nov 29, 2018 at 10:32 AM (Merged)
DAVE H
  • 13,384 POSTS
PARKING BRAKE
Parking Brake Shoe Adjustment (Expedition, Excursion, Explorer, Explorer Sport, Explorer Sport-Trac, Mountaineer & Super Duty Pickup)
NOTE:On all models except Excursion, Escape, Explorer, Explorer Sport, Explorer Sport-Trac, Mountaineer and Super Duty Pickup, parking brake system is self-adjusting and does not require adjustment.
Using Brake Adjustment Gauge (D81L-1103-A), measure inside diameter of drum portion of rear disc brake rotor. On Excursion and Super Duty Pickup, using parking brake adjuster screw, adjust parking brake shoe and lining until they drag against parking brake drum. On all other models, adjust parking brake shoe and lining to .020" (.508 mm) less than drum measurement.
FUNKMYDELIC
How do you adjust your parking brake?
  • 110,190 POSTS
Do you have rear disc brakes? If so, you are dealing with a design that isn't too good. There are actually small brake shoes that ride on the inside of the brake rotor that are for the park brake. You adjust them just a you would drum brake shoes.
ULTRARUNNER123
The parking brake assembly, inside the driverside rear wheel appears to dismantled into pieces. To avoid a costly expense, can i just remove the components so they stop rubbing against the rotor, and have no parking nrake. The cable has been disconnected from both wheels for awhile now, so its not that I would miss it. Is there any harm disengaging the mechanism, other than no having a parking.emergency brake ? Would you have an illustration/picture to go with it ?
  • 110,190 POSTS
I don't have a picture of the assembly. If you remove the shoes, it's not a problem other than you have no emergency brake, which as you mentioned, you already don't have. If you can afford to fix it, I would recommend it. I realize it's not the best set up, but in an emergency (brake loss) you'll be glad to have it.
2CAFASTANDFRIENDLY
a mechanic fixed the parking brake but it still does not hold. The parts he took out are brake shoes for drum brakes but I think (I can see thru wheels) that the car has disc brakes and rotor is clearly visible. Unless the parking brakes are separate set of brakes, am I being taken for a ride ?
Nov 29, 2018 at 10:33 AM (Merged)
  • 110,190 POSTS
Hi:
The rear disc has a drum in the center rear that uses brake shoes for the park brake. chances are he didn't properly adjust the brakes.
