2008 Ford Escape Radio Display Working Works Everything Else Could
2008 FORD ESCAPE
13,000 MILES
ANONYMOUS
radio display not working, radio works, everything else okay, what could problem be, and how to fix it.
Mar 17, 2013 at 7:03 PM
BIGBODINE
it's the display,we have a fleet and more of them don't work than ones that do.replacement is the only solution I have so far. CHeck the fuses. Here is a guide and thf use locations if okay replace the radio here is a video to walk you through the steps.
and
https://youtu.be/p_13d9FzsF0
Apr 1, 2013 at 11:13 AM
  • CAR REPAIR CONTRIBUTOR
either replace the radio or remove it and send it out for repair.
roy
Apr 20, 2013 at 9:24 AM
YANKEES46
Just noticed the light on my radio display does not work. I can read everything in daytime, just no light at night. Dash lights work fine. Local dealership tried to sell me a new radio to the tune of $480.00. I told them no thanks! Any ideas on the problem? Aside from the light, radio, CD player, etc all work fine.
Oct 29, 2019 at 2:33 PM (Merged)
  • 110,190 POSTS
What I would suggest is taking it to an automotive stereo shop. Chances are there is a bulb that can be replaced behind the front cover.
Let me know what you find.
YANKEES46
Joe,
Funny thing happened since I posted. It started working again. I pushed on the front of the display one night and all of a sudden the light came on. So I have not done anything since then. Sorry took so long to reply. I was having trouble getting logged in.
Thanks.
  • 110,190 POSTS
There is a light behind the face plate behind some of the factory radios. They burn out or in your case, it may have been loose.
Regardless, I'm glad it is fixed. If you have questions in the future, let us know.
MAXINEBALL
hello, i just got my 2003 ford escape transmission replaced, when i got it back, there was no power to my stereo?? he transmission worker took a quick look at fuses, but they were good and he said to come back monday cuz the man at the shop didn't have time to look at it, but could it need to be reporgrammed cuz he took the battery out??? help please???
THE FORD MAN
  • EXPERT
  • 38 POSTS
Ford radios do not require programming like other models. The radio actually has a few fuses. Does any functions such as back-lighting work? The radio might just have found a time and place to fail.
  • 31,937 POSTS
Check fuses 19, 20 27 in battery junction box,
MAXINEBALL
I have called the transmission shop that replaced it, they advised me to have it reprogrammed at ford dealership due to the fact that my interior lights don't come one or my fob keys don't lock my vehicle or radio doesn't have power, they said, it's a anti lock feature. I will be taking this vehicle in to get it reprogrammed again at ford dealership. Thanks :D
MAXINEBALL
hey there PHPAUTOS, i did get the technician to check it out quickly, but he said the fuses were ok.
